Page 168 of 186 FirstFirst ... 68118158164165166167168169170171172178 ... LastLast
Results 3,341 to 3,360 of 3706
    Aug 2012
    #3341
    Hirap talaga mag decide nyan Bossing, ganyan din ang nangyari sa akin last month.
    Una between ertiga and mobilio lang. tapos biglang lumabas new avanza.
    then plano namin bilhin ni misis yung Avanza 1.3 AT , and then we end up
    sa 1.5 G dahil full option na.
    Mar 2012
    #3342
    Quote Originally Posted by mekeni View Post
    Sir ano main difference nung G1.5AT sa E 1.3AT except sa obvious (engine)
    Mar 2015
    #3343
    Spoiler, Foglight, Hood Insulator, Chrome Grill, Chrome Trunk Lid, Abs, 15" Mags etc.
    Quote Originally Posted by jelocortez View Post
    Nov 2015
    #3344
    Mga sir's saan malapit dito sa Bacoor Cavite,Nag Vaccum ng Bangga, may maliit kasi na yupi sa rear corner bumper ko....
    #3345
    paki search nalang po sir sa google ung iba
    #3346
    Quote Originally Posted by 2pherpalaboy View Post
    Attachment 30239Attachment 30239
    Attached Thumbnails Attached Thumbnails 12233324_890442717692030_956131945_n.jpg
    #3347
    Ask only, Is that okay to run a 120kph specially for a new vehicle? Tnks
    #3348
    Quote Originally Posted by lech View Post
    Oo naman. Wag lang hard acceleration. [emoji5]
    Sep 2010
    #3349
    Eyeing at the 1.3a/t. How is the performance of the new dual vvti compared to the old one - acceleration, noise, refinement, gas consumption?. Probably those who had the chance to own both can share their experience.TY.
    Mar 2012
    #3350
    Can anyone explain the complexity on the Lighting indication ECO appearing and disappearing at times in Toyota Avanza 2016?
    Aug 2013
    #3351
    if the ECO light lights up, it means you are driving economically.
    #3352
    And how does "economical" translate into rpm, speed? Have anyone been able to observe these parameters when the light is on?
    Jan 2016
    #3353
    Sir avanza G 16 din yung akin pagka bili ko unang araw p lng matagtag or may klampag akong npansin at mrami p akong npapsnsin tulad ng pag e reverse mo may tumutonog nranasan mo b yan sa unit mo?
    Jan 2016
    #3354
    Tulad ng nagloloko din ang lock nya unang sraw p lng pagkuha ko sa ngayon pinabalik nila s akin check up daw nila muna lhat pati aircon di masyadong mlamig khit nka number 2 n ang sama ng loob ko kc cash ko syang nbili s dami ng concerned ko gusto ko ng papalitan ang unit kc araw p lng dami ng probs may mga gasgas at dumi p akong nkikita sa ngayon 3 days n sya s toyota wala pang sinabi kailan mtapos ang checkup ng car ko :-(
    Dec 2015
    #3355
    Mga Sir sino na sa inyo nakapaglagay ng AVT na double DIN headunit sa avanza? meron na din ba nakapagtry ng single DIN nla na may GPS bluetooth at reverse cam ndn? Avanza 2008 J model po gamit ko. balak ko kasi palitan na yung stock head unit niya. TIA
    Jan 2016
    #3356
    Sir would you still recommend the 2016 avanza? Or better pick a 2nd hand tested avanza or a brand new ertiga??
    #3357
    Quote Originally Posted by romantiko View Post
    Ertiga rides better than the avanza. The 2016 avanza has newer dual vvti engines. Test drive the two before you choose
    Oct 2015
    #3358
    Greetings from Avanza Club Pilipinas Inc.
    The Avanza Club Pilipinas Inc. is a group of Toyota Avanza lovers and owners from the Philippines established in Tsikot since 2006 with SEC Registration Number: CN201517636. Our clubs mission is to help our community by sponsor one charitable institution. It also promotes camaraderie, harmony and education to promote safety in driving, automobile maintenance and improve vehicle operation.
    _https://www.facebook.com/groups/avanzaclub.ph/
    please remove the underscore to direct to to site.
    Jan 2008
    #3359
    A couple of days ago, I had our 2007 Avanza 1.5 GL AT checked out due to a knocking problem near or at the engine. My mechanic at Kitanlad (near Banawe) found that the Transmission support was already destroyed and meron na daw lamat yung right hand (RH) side na Engine support. He also found an oil leak at the Flywheel oil seal (at rear of engine daw). Due to the lack of time, only the Transmission support and Flywheel oil seal were replaced (with original parts c/o Toyorama).
    7 PM na ako umalis doon because coding yung car and when I finally left, I found out na hindi gumagana ang speedometer and the car wouldn't change gear (upshift). The following morning, this was promptly diagnosed as a faulty Speed sensor, as in naputol/nabiyak siya. Sensing that my mechanic and his boys were somehow responsible for this, I asked them to remedy the problem, which they eventually did by soldering wires to the 3 connectors to maintain the continuity (see pictures).
    Tanong ko lang po sa inyo:
    1. Do I need to have the Speed sensor replaced by a new one?
    Note: Wala naman akong napansin na problema with the said part for now, pero baka naman magluko in the future. As per Toyorama, original part lang ito and order basis pa, around P7K. As for surplus, meron daw mahahanap yung mechanic ko, baka daw mga P2,500.00.
    2. Do I still need to have the RH Engine support replaced:
    2.1 With original part for just the RH side, around P3K; plus labor, P???
    2.2 Or with replacement part for both sides na, P700 x 2; plus labor, P???
    Note: I noticed the disappearance of the knocking sound, but as per my mechanic meron nang lamat yung RH Engine support.
    Sana po ay matulungan ninyo ako at mabigyang linaw ang aking pinuproblema.
    Attached Thumbnails Attached Thumbnails 20160204_112949.jpg   20160204_112956.jpg   20160204_113003.jpg   20160204_113015.jpg
    #3360
    Quote Originally Posted by yellahfellah View Post
    my opinions:
    1. if they cut the wires earlier during the fix, but re-soldered them back and the part functioned as before, then i believe you don't have to replace it. BUT... just looking at the fixed item, i think amateur me can do a better job of soldering and dressing them. the tape might unravel over time..
    2. if the part is already showing signs of impending failure, i'd have it replaced. if it fails, baka mandamay pa ng ibang piyesa.. as in, mapapadali ang sira ng ibang support. i think this is what happened to the RH support.. na-damay nung nasirang suporta sa kabila.
Toyota Avanza Owners & Discussions [continued]
