Page 172 of 186 FirstFirst ... 72122162168169170171172173174175176182 ... LastLast
Results 3,421 to 3,440 of 3706
    Dec 2011
    #3421
    yan nga yun, san banda yang shop ?
    #3422
    Quote Originally Posted by sitcoms View Post
    Just follow the lead I gave you sir.
    Oct 2015
    #3423
    Newbie here, been using my 2016 avanza E 1.3 AT for the past 7 months. No problems naman so far happy naman ako and no regrets. Mejo bitin lng sa power when i need it, also i feel bitin lang din sa shocks pati breaks. Fc 8.9 kml city driving. Will have first pms this month. I hope cheap lng ang maintenance.
    Aug 2016
    #3424
    anu po avaerage fuel consumption ng automatic
    2012 model
    1.3 at
    or 1.5 at
    pinagpipilian ko po kasi. di ko po maback track thanks in advance
    Sep 2016
    #3425
    I've been experiencing problems with our Avanza 2008 model every year. Last year we spent more than 70k total for the troubleshooting then ended up with overhaul.
    Now, the aircon is not working. Toyota said we had to replace the magnetic clutch which cost 28k+ but the other shop gave a list of parts that need to be replaced but there's no magnetic clutch on the list with total cost of only 12k+. Obviously both have different diagnosis and I don't know which one should we go for.
    Not sure if Toyota tried to check the basic problems like blockage in the airflow, aux fans and etc...
    Our avanza also is shaking when idle or when in neutral mode. I'm just as much as possible trying to avoid another costly fix by toyota.
    List of problems;
    1. Shaking when Idle
    2. One window doesn't roll up or down
    3. Aircon is not working
    4. When running on uphill, it slides down.
    5. Small sticky rust forming inside the radiator
    #3426
    Quote Originally Posted by ani View Post
    List of problems;
    well... if you must know.. the avanza is a daihatsu with toyota tatoo.
    28K kesos for magnetic clutch. ng aircon compressor?!!
    dalhin nyo po sa banawe. wala pang 3K ang siningil sakin, nung nagpa-palit ako sa non-avanza car ko.
    also, bilib pa ako sa aircon shops sa banawe. cheaper and "they seem to know what's wrong with the aircon". but we also have to be discernible, to differentiate the "must-replace" from the "replace before it fails" (because it may take several more years before it does fail).
    ...#4. it rolls back when going uphill!! horrors! sounds expensive...
    MT? baka clutch lang..
    AT? double horrors! $$$
    Sep 2016
    #3427
    You're right. That's why I want to go to the other shops who are experts in fixing air conditioning system. I'm in BOHOL. Oh my goodness are you sure it's double horrors for automatic transmission?
    Sent from my MotoE2(4G-LTE) using Tapatalk
    Sep 2016
    #3428
    Hello Po,
    I just recently bought avanza and my challenge was the side mirror was manual. I am planning to change to an all power sana para hindi na ako palaging mag aadjust.
    any idea if magkano po magagastos and saan ang marerecomend nyo na work shop?
    Salamat in advance.
    #3429
    Quote Originally Posted by chinaykl View Post
    Hello Po,
    Salamat in advance.
    if you are the only one driving the car, you may not really need power side mirrors, po.
    i probably adjusted mine, less than 5 times since i bought it 4 years ago.
    #3430
    Good day to all.
    Ask ko lang po kung anong possible problem sa Avanza 1.5G ko, model 2010 po siya. No problem naman eversince, and satisfied owner po ako until my wife sends me a message na ang power windows, fan and aircon and signal lights ay ayaw ng mag work. All the rest ay ok naman including engine performance. Tried to gave them instruction to check fuses pero ok naman daw (but not sure kung may marunong mag check ng fuses).
    Maliban sa mga fuse, ano pa kayang pweding sira niya? Wala akong regret sa Vanzi ko, FC niya sa highway up to 14 km/li.. at average 80km/hr, city not heavy traffic as Manila around 10km/li.
    Best regards,
    Jun
    Sep 2016
    #3431
    Do you know if the 2008 Avanza Automatic has aux input or can it be set up to play music thru Bluetooth?
    #3432
    No Bluetooth but it has aux input.
    Oct 2009
    #3433
    SOS Pls! Humina yung air flow ng front aircon ko, dati nasa #1 lng ok na ngayon dapat naka #2 sya at hindi pa ganun kalakas, pero wala namang problema sa lamig. Nasa condition pa rin yung rear aircon. Ano po ang mainam gawin dito. pls patulong sa may alam. Thanks.
    Oct 2015
    #3434
    Try changing or cleaning the cabin air filter. Usually located behind the glove compartment.
    Baka kase madumi kaya mahina flow ng air.
    Nov 2016
    #3435
    toyota avanza 1.5 G 2013 A/T 30k mileage more or less second hand, price is 485K do you think is a fair price na? company own kasi yung first owner daw nag upgrade to innova so trade in niya sa dealer tapos innova na kinuha niya. 2 years na daw ginamit yung car. ano po comment niyo thank.
    Aug 2012
    #3436
    Quote Originally Posted by rloinm33 View Post
    Fair enough. Pwede mo pa rin tawaran.
    2013 Avanza 1.5 G M/T price in OLX is P465k to P475k.
    Sent from my D5833 using Tapatalk
    #3437
    Quote Originally Posted by red_one View Post
    but you have to really check the condition of the vehicle.
    a major issue can easily wipe clean the 20K "advantage". maybe even more.
    Nov 2016
    #3438
    Hello all, I have a 2010 avanza. now i have problems with my radiator fan. sometimes its working sometimes it not. na feel ko din na lumakas vibration once ang fan is turning.. I saw another thread here na need to replace daw yun fan or motor ng fan.. Anybody who has the same experience?
    Dec 2016
    #3439
    Hi ALL,,
    Need ko ng help.. plan kase namin ng kapatid ko bumili ng 7 seater na car. ang pinagpipilian namin is between Suzuki Ertiga or Toyota Avanza.. Which one kaya ang BEST in terms of city driving, fuel efficient and better 7 seater car.. naguguluhan na kame sa mga advice ng toyota at suzuki eh.. Pa reply naman ng advice. salamat peps..
    Dec 2016
    #3440
    Quote Originally Posted by conan View Post
    Hi ALL,,
    Which is better: Ertiga GL or Avanza E both matic
Toyota Avanza Owners & Discussions [continued]
