Page 163 of 186 FirstFirst ... 63113153159160161162163164165166167173 ... LastLast
Results 3,241 to 3,260 of 3706
    Dec 2011
    #3241
    1.3 MT namin 3200~3500 rpm * 100kmh
    Jul 2015
    #3242
    Thank u bro.
    Jul 2015
    #3243
    Ang mahal pala nung nilalagay sa tabi ng handbreak ung parang taguan ng mga gamit. May alam ba kau na mura nabibilhan?
    Jul 2015
    #3244
    Good day Sir/Maam!
    Planning to buy here Avanza 1.3E but still confused if going with Manual or Automatic transmission. Need your expert advise on this one. things to consider are as follow:
    1. will be using this mostly in Cavite area. sometimes city (EDSA area) driving like once or twice a week only.
    2. in terms of fuel consumption, which transmission saves better?
    3. when planning for a long drive (like 6-8 hours going north), which transmission is better on this one?
    4. overall difference between fuel consumption between these two transmissions? just seen some articles that nowadays, there's a lot of improvements with matic transmission and there's no huge difference with a manual with regards to this one. is this true for most cars?
    As you can see, my most concern here falls on the fuel consumption. but if you already tested these two types, will you recommend a manual or automatic? will be purchasing my first car so don't have any idea yet so need to gather info on this one.
    Aprreciate in advance your help and thanks in advance!
    Regards,
    Jhay
    Jul 2015
    #3245
    Good day Sir/Maam!
    Regards,
    Jhay
    #3246
    Quote Originally Posted by mc241q View Post
    Good day Sir/Maam!
    Regards,
    Jhay
    2011 avanza J everyday Bacoor Cavite -> BGC. medyo matraffic sa pag uwi. consumption is around 11kms/ltr.
    the best consumption i had, if i recall it correctly, is around 13-14 km/ltr. rektahan drive to.
    no idea with the a/t though.
    Good day Sir/Maam!
    Regards,
    Jhay
    This is true for Mazda Skyactiv transmissions
    Toyota 2015 Avanza is still using the 4AT from 10 plus years ago.
    If FC is your priority then go for the 5MT Avanza.
    Aug 2012
    #3248
    I like the new look.
    #3249
    Quote Originally Posted by nuclei View Post
    Here are some info on the AT Avanza 1.3, Been monitoring my FC on a spreadsheet since I bought the car last Jan 2015.
    averaging at 9.4 km / liter, on 20 full tanks so far . route is at 70/30 share for City/Highway
    City Driving is just 8.1 km/Li, was able to achieve 13.3 Km/Li on a Bicol trip a couple of months ago.
    Overall, I would still prefer the AT for the added convenience.
    The added FC somehow makes everyday traffic driving a lot more bearable.
    Aug 2012
    #3250
    Pa-confirm naman mga bro if wala talagang 12V socket ang 2nd gen. Avanza, 2012-2015? Nabasa ko lang sa review kasi.
    #3251
    Quote Originally Posted by red_one View Post
    Meron, isa lang sa gitna.
    Sep 2005
    #3252
    sa kanila nasa 765K lang 1.5 matic
    New 2015 Toyota Avanza Debuts In Indonesia With Dual VVT-i Engine | Carlist.my - Malaysia's No.1 Car Site
    Power is now up by 1 PS, to 104 PS, still peaking at the same 6,000 rpm. Torque remains at 136 Nm, but is now achieved 200 rpm earlier, at 4,200 rpm.
    The smaller 1.3-litre unit sees slightly more improvement. From 91 PS to 96.5 PS, still peaking at the same 6,000 rpm. Torque is up by 4 Nm, to 121 Nm, also achieved 200 rpm earlier at 4,200 rpm.
    Prices start from IDR 204.2 million for the 1.3-litre Manual, reaching up to IDR 226.9 million for the 1.5-litre Automatic.
    Aug 2015
    #3253
    Sir Buying Center console with arm rest for Avanza 07
    Thnx.. Respect
    Aug 2015
    #3254
    Hello Avanza Owners. wanted to check you have a similar experience:
    1. Avanza Engine Light is turn on
    2. Scanner Result is P1346 error - camshaft sensor error
    3. toyota replaced the sensor but it did not fix the issue, the next day same error occurs.
    4. Toyota is now recommending to change the timing chain to setup the timing that likely cause the error.
    Any recommendation?
    Oct 2014
    #3255
    Good day Avanza Users,
    Paadvice naman po ako if fit po yuong side mirror ng avanza 1.5 into avanza 1.3..Salamat po
    Oct 2014
    #3256
    Sir gumagana ba yuong Speedometer cable mo? IF not yun po ung caused.
    Apr 2010
    #3257
    Quote Originally Posted by bangul View Post
    anong year model po sir bangul?
    #3258
    i wonder... will the fuel efficiency improve with this new engine?
    if yes, i might be persuaded to consider getting one..
    Aug 2005
    #3259
    Mga bossing. ano po ba ang PCD size ng Avanza. kasya ba rim ng vios?
    salamat po..
    Jun 2005
    #3260
    Quote Originally Posted by lance_899 View Post
    salamat po..
    afaik PCD114 avanza.
    PCD100 ang vios
Toyota Avanza Owners & Discussions [continued]
