*wrock - actuator na yan sir.. mura lang yan.. dalhin mo kay Jimson sa banawe.. 150 lang yata isa..
sa gulong.. parati akong 35 psi.. nasanay na ako sa tagtag.. every month papahangin ako... usually nababawasan nang 2 to 3 psi every month..
Kung may konting kakayahan sa pangangalikot, madali lang ito malaman.
1. remove the black triangular plastic cover a salamin (front-forward portion of the window). sundot sa ilalim and pull out.
2. remove the lock/unlock handle by unscrewing.
3. remove the screw in the door opening handle at sa armrest containing the controls for the power windows.
4. from the bottom, slowly pull out the door trim cover, till it comes free from the door.
5. Palusutin mo na lang ang door opening handle at ang arm rest in their respective openings in the door trim. trim is removed.
6. trace the locking lever mula ta-as pababa sa solenoid.
7. If you notice, merong panibagong solenoid na naka-kabit, with a stem connected to the original locking lever stem. the first one is the original solenoid, the other one is for the car alarm.
8. now lock the car and observe its action (the movement of the 2 locking lever stems)
9. unlock the car and observe kung sumusunod ang lever pata-as or it is just sliding through.
10. By the way, why not try using the original keyless entry? It is still functioning kahit meron ka nang ikinabit na panibagong car alarm system.
HOPE THIS HELPS.
Di pala maintenance free ang battery ng avanza. Ngayon ko lang napansin, buti na lang nag check ako. Ngayon lang kasi ako nagkaroon ng hindi maintenance free. Ano ba dapat i-check maliban sa tubig? Thanks.
tubig lang i che check.. just put ordinary distilled water.. make sure wag mag over flow..
ask ko narin pala mga sir/maam napansin ko lang po thou its not a big deal to me but just the same normal lang po ba na medyo magalaw or parang nanginginig yung speedometer ko from 20kph-60kph pero at higher kph ok lang sya and steady/swabe lang pag akyat. ok naman po tapak ko sa gas pedal at di naman po nag jejerk si vanzy habang umaandar.
should i be bother one this one and have it check sa casa kasi sa ibang sasakyan namin ok lang pag akyat/swabe naman unlike my vanzy....
Nasa manual din yan sir, sa 1.3 Rear:35, Front 31, pero gamit ko ay 30 lang, noong nasa maximum recommended psi ako, matagtag masyado sa mga pangit na concrete road. Kung sobrang baba naman, malakas sa gas.
with due respect, some procedure di applicable especially sa pagbaklas ng door trim sa kanyang 1.3 na avanza...hehehe
Pero yong actuator check, ok yon. +1
may level marking yan bos, absolote or wilkins distilled water lang ang katapat, make sure naka park ka ng straight ang level ng ground. since more than 1 year na ang avanza ko, 3x palang ako nagdagdag.
Speaking of distilled water, yan na din ang gamitin mo pang top up ng coolant(hwag mong punuin eto, may level mark din yan), distilled na din sa windshield washer
Doc, never experienced with that probs kahit ilang ulit ko nahugot kabit ang cable sa instrument panel. bos dreamer21, Pacheck nyo sa casa sir, could be the instrument itself may probs or a loosen cable.
(Sent from GT-I9003)
hello po.
tanong ko nga po,paano po ang usapan kapag may nabangga o nasagi at nayupi o gasgas ang isang sasakyan, halimbawa po ako ang nakasagi o nakabangga?
may comprehensive ins po ako at ang isa ay wala.
At pano naman po kpag parehong may compre. ins.?
What if, kung ako naman po ang nabangga o nasagi, at ang nakabangga o nakasagi po pareho kaming may comp ins?At paano po kung ang isa ay wala.
Ano po ang dapat o magandang gawin?
Pansensya na po sa maraming tanong.TIA
hmmm.. magulo nga yan.. teka..
kung ikaw nakabangga, tapos may compre yung binangga mo, pwede nyo siguro ayusin yan na compre nya gamitin at ikaw ang babayad sa participation nya..
kung pareho kayo meron, siguro call it quits.. wala naman siguro kayong intensyon na bumangga, in other words, disgrasya talaga..use each insurance to cover all the repairs of your own vehicles as own damage..
kung ikaw ang bumangga, ikaw meron compre tapos yung binangga mo wala, i think its fair na you pay for the repairs. di mo naman magagamit yung compre mo sa car nya, but magagamit mo sa repairs ng car nyo as Own Damage..
these are my thoughts on these.. hope it helps.. but feel free to ask out for more help...![]()
