Page 410 of 749 FirstFirst ... 310360400406407408409410411412413414420460510 ... LastLast
Results 8,181 to 8,200 of 14970
    #8181
    Originally Posted by Marfin
    Eto nga pala list mga orders ninyo, pasensya na po yung walapa siguro next batch nalang ulit (end of march).
    Sa distribution naman, siguro masmaganda kung makaka attend po kyo ng EB as suggested by forum .
    Frontgrill Chrome
    ...angelito
    ...meledson
    Mudguard
    ...puroy
    Consolebox
    ...jefferson
    ...instech
    BodysideMoulding (blackw/chrome lines)
    ...bisoy_96
    CoverMirror w/ Led
    ...Islaw_Palitaw
    PowerSideMirrror w/ Led
    ...Meledson
    EngineCover (under)
    ...wohoo
    Foglightcover
    ...ErwinNP
    Pullhandles (forum suggested raffle nlng daw)
    < Gray, only 5pcs available>
    ...Meledson 3
    ...dfsantos 2
    ...shadow 2
    ...harryparot 6
    <Biege, 6pcs>
    ...lenuj 2
    ...ErwinNP 2
    ...MMMan 2
    Extra items:
    Chrome Wiper cover 2pcs
    RuberSillplate (black) 1pc
    Sir Marfin yung rubber Sillplate ba na black na 1 pc. un ung inilalagay sa likod na door. Kung un nga iyon kunin ko na lang how much po sya? TIA
    #8182
    Hi there thanks for posting your replies ! indeed a great help.
    I also strongly agree to IMM29 that oil needs to be changed every 5000kms
    by the way what particular brand of oil are you guys using? kasi i had used semi synthetic (shell) di jkasi maganda hard starting eh taas ng rpm agad!
    also am suing all original casa oil filter.
    well need comments.again thanks for your help!
    Dec 2007
    #8183
    Quote Originally Posted by qtshecu View Post
    just a quick question, suppose ung gear natin nasa 5th or 4th gear, when decreasing the speed, do u normally shift down one gear at a time? or let's say, from 4th gear, derecho 2nd gear?
    what's the best practice? kc ako i usually shift down one gear at a (5th to 4th, 4th to 3rd, 3rd to 2nd).
    Have you ever observed a multi-speed bike (5-speed, 6-speed, 18-speed, 21-speed, etc...)? Have you ever used one? Para ka ring nagmamaneho ng kotse. Habang lumalaki yung gear na gamit sa likurang gulong, mas madaling ipadyak ang bike. Ito yung equivalent ng gear natin sa transmission ng kotse.
    (Yung gear naman sa may pedals, habang lumalaki, mas humihirap ang pagpadyak. Sa Avanza natin, walang direct equivalent ito.)
    Each gear has a ratio. See: http://www.howstuffworks.com/gears.htm
    I'm not sure kung nakasaad sa manual ng Avanza ang speed ranges na kaya ng bawat gear katulad ng ibang car manuals na nakita ko na. Pero generally, ang minimum speed sa bawat gear lang ang tinatandaan... although in my case, sa tagal ko nang nagmamaneho, tinatantiya ko na lang... kapag sanay ka na kasi, ang sasakyan ay parang extension na lang ng katawan, e. "I just know(knew)," sabi nga ni Pistol Pete Maravich... parang natural na lang...
    Ngayon, balik sa tanong mo... sa pag-slow down, usually dapat ilagay mo sa neutral kasabay ng preno, lalo na kung medyo mabilis dapat ang pagbagal mo (kapag biglang bumagal/nagpreno ang nasa harap ng sasakyan mo), tapos ilagay mo sa tamang gear kapag pwede nang bilisan ang takbo.
    Kapag super-bilis ng mga pangyayari, at kailangan mo ng tulong sa pagtigil na sa tantya mo ay di kaya ng pagpreno lang, tutulungan ka ng tinatawag na "engine brake" -- ito ang pagkambyo nang mas mababa sa kasalukuyang naka-engage na gear (e.g., naka-5 ka, preno ka sabay kambyo sa 4th o 3rd, depend sa speed range ng gear).
    Sa VIOS G A/T owner's guide: 92kph ang maximum sa segunda ("2" position), at 46kph naman sa primera ("L" position).
    Hope this helps...
    Nov 2006
    #8184
    Wala ba kayong napansin kay Pres?
    Moderator na ang title ni Pres MelEdson. [SIZE="4"]Congrats Pres![/SIZE]
    Aug 2005
    #8185
    Quote Originally Posted by dfcsantos View Post
    Moderator na si Pres MelEdson. [SIZE="4"]Congrats Pres![/SIZE]
    Kagabi, di lang ako ang nadagdag na moderator dito sa tsikot. :D
    Aug 2005
    #8186
    Ang mga bagong makina, pag start, mataas kaagad ang RPM para mag-init kaagad.
    Pag malamig pa ang makina, di pa ito efficient. Pag na reach na ang optimal temp, bababa na ang RPM.
    #8187
    Congrats Pres...napansin ko din yan kanina, pati kulay ng username naiba at naka bold.
    Nov 2007
    #8188
    Quote Originally Posted by lenuj View Post
    Quote Originally Posted by Marfin View Post
    ..almost forgot ang price list pala
    CoverEngine,under(orig)........................... ...........2000
    FoglightCover(orig)............................... .............1200/pair
    PowerSideMirror kits w/ Led ................................8000
    PowerSideMirror kitsw/ Led (NEW)......................10,000
    PowerSideMirror no Led......................................7500
    Pullhandles(orig)................................. ................300
    FrontGrill Chrome............................................ ...1000
    Innova type FrontGrill........................................ .1500
    Mudguard.......................................... ...............1100
    ConsoleBox........................................ ...............2000
    BodysideMoulding<black w/ chromelines>................1500
    BodysideMoulding<body color thin>(orig).................2500
    CoverMirror Chrome G-Type w/ Led........................1500
    CoverMirror J-Type.............................................. 900
    Schuffplate Chrome(aftermarket)...........................1000
    [SIZE=3] SchuffplateOuther cover........................................600[/SIZE]
    Wiper cover chrome............................................ .700
    BaseCarpet(leatherate)............................ ...........2000
    Emblems........................................... .................250
    Wooden Panels set G-Type only............................2250
    Spoiler w/ Led............................................... ....4750
    Centralock kits.............................................. ....1200
    Remote+Alarm...................................... .............1200
    RainGutter/visor............................................. ....1750
    Backplate garnish chrome....................................1100
    Doortrim kits(4door+switches)c/o daihatsu...............20k
    Eto nga pala picture yung scuffplate na outher cover, eto po ba sir yung sinasabinyo?
    at yung chrome wiper cover nakakabit sa vanzy ko.
    Sep 2005
    #8189
    where do you service your avanza?? is this still under warranty?? Coz the CASA told me that they don't let owners use any ordinary oil, for warranty purposes..
    Quote Originally Posted by avanzazgy View Post
    Nov 2007
    #8190
    Congrats Mr. pres. 1700+ pala ang kailangan total posting natin para maging moderator. Malayo pa kami jan...
    Aug 2005
    #8191
    *marfin,
    ano ang pinagkaiba ng old and new power side mirrors?
    Sep 2005
    #8192
    aba moderator na pala si president!! congrats!! ala bang blowout dyan sa EB??
    Jan 2008
    #8193
    Regarding insurance, In-house insurance (Standard) na ng Toyota ang kinuha ko kasi in-offeran ako ng SA ko ng mababa, lower compared sa banko. Plus, sabi nya mas madali daw mag-claim kung in-house. 3 installments pa ang ibinigay sa akin, plus isinama na rin ang 'Acts of God', kaya OK na din.
    One day lang ang approval sa bank. Then nag-P.O. na ang bangko sa Toyota. Medyo natagalan lang i-release yung unit kasi walang available na Metalic Blue that time, naghintay ako ng > 1 week, then nagdecide na kunin na lang ang Champagne color na available sa branch (anyway ito naman ang 1st choice ko). In two weeks, na-deliver na sa house namin yung unit.
    Quote Originally Posted by GG4 View Post
    Thanks for your advice,regarding sa insurance dun na rin ba kayo kumuha or pwedeng sa labas na lang.Sa case nyo madali ba ang approval at na release na agad ang unit?4 weeks lang kasi ako dyan satin then balik na naman akong abroad.Thanks again and more power to avanza club!
    Aug 2005
    #8194
    Wala sa number of posts. Sina jedi at doc tsikot ang puwedeng gawin ang isang tsikoteer to moderator. Sina liv, ooba, and thepatriot parang less than 1,000 ang mga post nila each pero kasabay ko na na upgrade to moderator.
    BTW, moderator lang ako ng Avanza Club sub-forum. Si liv sa Innova, sina ooba and thepatriod sa strada and mitsu.
    Aug 2005
    #8195
    BTW, do not use oil addditives. Mas nakakasma ito than nakakatulong.
    Aug 2006
    #8196
    In my experience a regular change oil every 5K of mineral oil is better than having a fully synthetic every 10K.
    I had a 96 Lancer itlog religiously getting mineral oil every 5K and still performs smoothly, the last time I opened the cylinder head cover there was no sign of sludge and grime residue.
    The truth is, when we got our units from the dealership, it came with mineral oil and not fully synthetic, evidently our units are factory tested using mineral oil
    It will be your choice now who to follow?
    Use mineral oil as standard oil for your car set by the car manufacturer or follow those oil companies to use synthetic oil and have a prolong change oil interval to offset the cost they are raking from your pocket.
    May 2007
    #8197
    Sa Avanza sub forum, pag kita mo ang "Avanza Club Private Forum" may access ka. Actually mayroon nag padrino sa iyo Sorry, di ako.
    Kaso ng naisubmit ko ang list, mali ang username mo, nakalimutan ang "_". Any way na PM ko na si tsikot and kung di mo pa kita ang Private forum area, di magtatagal ay magkakaroon ka na rin ng access.
    Thank you po sir. Wait na lang me....
    May 2007
    #8198
    Quote Originally Posted by FURdi_licious View Post
    sir dfcsantos, maraming salamat po.
    mayroon lang po sana akong imumungkahi para sa club website kung ok lang sa lahat na magkaroon sana tayo ng additional list of highly recommended suppliers and services para sa rides natin base sa mga recommendation ng mga members din po natin. for example, seat cover - name of Shop - price tag - recommended by (name). easy references kung baga kaya lang additional job ito para sa webmaster po natin. ito ay suggestion lang po para din sa lahat.
    cheers!
    *FURdi_licious:
    Recommend mag start ka na rin ng threads entitled "Seatcover" and "Best Services". I think madadagdagan ang T-cash mo. Tama ba yun, Mr President/Moderator?
    May 2007
    #8199
    Congratz, Mr President/Moderator!
    Aug 2005
    #8200
    Quote Originally Posted by AvAnzA_84 View Post
    *FURdi_licious:
    Every post ay may corresponing Tcash. Actually, di na ako masyadong interesado sa Tcash.
    Kung gagawa ng new thead regarding the Avanza, paki state lang ang word na Avanza sa title para madalaing ma search. Thanks.
Toyota Avanza Owners &amp; Discussions [ARCHIVED]
