Results 41 to 49 of 49
July 25th, 2013 03:32 PM #42
July 25th, 2013 03:58 PM #43
- Aug 2006
- 728
July 25th, 2013 04:54 PM #44With my accent at 100km/hr 1.8k RPM. It doesnt matter if mag shift ako early or i hataw ko and paabutin ko to 3k ang rpm at 1st 2nd and 3rd gear to 6th.. Basta pag stable na ang takbo at pumatak na ako sa 100km/hr yung RPM ko will stay at 1.8k at 100km/hr... Again kahit na mabagal at mabilis ako mag shift.. basta 100km/hr my rpm is always at 1.8k
- 54,226
- Jul 2011
- 584
July 25th, 2013 10:25 PM #46speed of the car is directly proportional to gear ratio, you can not cheat actual speed for a given RPM and gear.
ex.
Toyota Innova
Gear Ratios/kph per 1000rpm
1st 3.928/7.71
2nd 2.142/14.15
3rd 1.367/21.69
4th 1.0/30.31
5th 0.851/35.62
Final drive 3.909:1
Source: Indiacar.com
Formula:
Engine Rpm / Gear Ratio / Final Drive Ratio X Wheel Circumference (Inches) X 2.54 / 100000 X 60 :
(1000 / 0.851 / 3.909 ) * 80.519 *2.54/100000 * 60 = 36.88
1500 RPM -> 55.32
2000 RPM -> 73.76
2500 RPM -> 92.2
3000 RPM -> 110.64
Source: Team-bhp.com
- 54,226
July 25th, 2013 10:37 PM #47
Tsikot Member Rank 4
- 2,719
July 26th, 2013 12:11 AM #48
- Jul 2011
- 584
July 26th, 2013 12:46 AM #49yes it must match, if the tyre/gear ratio your computing is the same size with the example.
but on the speedometer it will not match, as the speedometer is not accurate reflection of the car speed.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
