Results 31 to 40 of 49
July 25th, 2013 11:54 AM #31
1st gear rev to redline
2nd gear rev to redline
by 3rd gear you'll be doing 100
by 4th gear you'll be over 120
if you're doing 80 at 5th gear that means you didnt rev high enough from 1st to 4th
what's there not to understand?
July 25th, 2013 12:08 PM #32
July 25th, 2013 12:09 PM #33
Meron ba nakasubok na iba na 2e din, 2,700rpm at 5th gear. Baka nga naman dapat above 80kph na.
July 25th, 2013 12:11 PM #34
July 25th, 2013 01:00 PM #35
Tsikot Member Rank 4
- 2,716
July 25th, 2013 01:58 PM #37
To the TS:
One poster said he's reading 3000 rpm, while you're getting 2700 rpm, if both your cars are of the same model, same engine, etc, then gearing is not an issue. Does your Corolla have a factory (stock) tachometer or aftermarket?
July 25th, 2013 02:14 PM #38
Ito naman sa akin. Nissan Vanette 2.0
Please Note that the Actual Speedometer reading is Off by Approximately 10kph.
Checked it with 2 different GPS device. True Speed is 115 kph at 3200 RPM - 5th gear.
81 kph at 2250 RPM - 5th Gear
What I think is it has nothing to do whether you shift early or not. It's the gear ratios of the transmission.
This is My understanding..:peace:
July 25th, 2013 02:20 PM #39
2E 2E 2E 2E
[ame]www.youtube.com/watch?v=5a9_NY-0qSk[/ame]
so 80 at 2700?
too slow
July 25th, 2013 02:58 PM #40
Hybrids and EV
