on my previous 2E, cruising at NLEX with a speed of 100kph registered a 3000rpm on a tach![]()
mga ka tsikot,ang ibig ko po sabihin e, kapag tumatakbo po ako ng dretso sa hi-way ng 80kph nasa 2700rpm ko. tanong ko lang po sa mga may 2e engine kung ganyan din po reading ng rpm nyo kapag tumatakbo po kyo ng 80kph. salamat po sa mga nagreply.
it depends on the car's gearing.
on my getz, 2.5k rpm at 80 kph, 3k rpm at 100 kph, 3.5k rpm at 120 kph.
on my sentra, 2.2 rpm at 80 kph, 2.5k rpm at 100 kph, 3.0k rpm at 120 kph.
on my corolla, the same as the getz.
last week, went to zambales using a vios.... almost the same as the getz, but at 3.8k rpm, 140 kph na takbo.
Agree, - depende sa gearing at size ng gulong:
Sa mga AT na rides:
Innova Gas - 3KRPM at 100KPH (4AT ito)
09 City - 2KRPM at 100KPH (5AT ito)
GS - 2KRPM at 100KPH (4AT ito)
20.2K:flush:
I think the 80kph to 2700rpm is ok for hte 2E rolla.
maikli talaga gearing 90s corolla,
maski ako i had a 95 GLi variant before, maikli lang din.
lakas torque pero mababa topspeed.
toyota 2E
reach 80 at 2nd gear
[ame]www.youtube.com/watch?v=QICnmSXUgAQ[/ame]
[ame=http://www.youtube.com/watch?v=tPvPqVEeL90]Toyota Corolla 1.3 XLi 0-100 km/h - YouTube[/ame]
agree din ako na masyadong maaga mag shift kaya mababa speed.
ganito ang driving style ko pag nasa economy mode
Sent from my GT-N8020 using Tapatalk 4 Beta
1st gear rev to redline
2nd gear rev to redline
by 3rd gear you'll be doing 100
by 4th gear you'll be over 120
if you're doing 80 at 5th gear that means you didnt rev high enough from 1st to 4th
what's there not to understand?
Meron ba nakasubok na iba na 2e din, 2,700rpm at 5th gear. Baka nga naman dapat above 80kph na.
To the TS:
One poster said he's reading 3000 rpm, while you're getting 2700 rpm, if both your cars are of the same model, same engine, etc, then gearing is not an issue. Does your Corolla have a factory (stock) tachometer or aftermarket?
Ito naman sa akin. Nissan Vanette 2.0
Please Note that the Actual Speedometer reading is Off by Approximately 10kph.
Checked it with 2 different GPS device. True Speed is 115 kph at 3200 RPM - 5th gear.
81 kph at 2250 RPM - 5th Gear
What I think is it has nothing to do whether you shift early or not. It's the gear ratios of the transmission.
This is My understanding..:peace:
2E 2E 2E 2E
[ame]www.youtube.com/watch?v=5a9_NY-0qSk[/ame]
so 80 at 2700?
too slow
