Mga sir, yung washer fluid ba, water lang yun?
Since tag ulan na, ano floor mats gamit nyo?
Lastly, anyone knows where I can buy a seat booster junior size for my 6 year old kiddo?
TY
Saw this in topgear. Tibay ng tail lights ng vios haha
Posted via Tsikot Mobile App
well, if the tint significantly diminishes your ability to see, the most obvious and effective solution is to have the front windshield's tint removed.
many states in the USA prohibit full tints in the front windshields; they do allow a thin strip at the top, 'ala sun visor..
this reminds me of the guy who wanted to upgrade his headlights, because the front windshield tint he had, was hindering his vision... funny...
there are maintenance tables in the manual... some DIY-able, others casa-musts. the manual does not command you in glowing letters, what to check. you have to look and read between the lines.
but if you look at the index, it will show you where the engine coolant, the brake fluid, and the windshield washer fluid containers are... they will show you how to check engine oil. they will show you the correct fluid levels, and recommend to you what particular fluids to add, in case more fluids are in order.
it may initially be a bit scary, especially to one who has not done it before, but these are really easy to do. ask a pal or friendly mechanic how to do it.
Buy Toyota coolant. Never put plain water in your cooling system.
Read the manual to know what and where to check.
judging from what i read between your lines, i suggest you ask a pal or a friendly mechanic to teach you how to do these things. they're really easy to do, once you've done 'em even once.
they're even easier than putting air in your tires, because you don't have to bend your waist that much.. heh heh.
Mga sir magkano naggastos nyo sa 1000 & 5000km check up? Mineral oil lang.? Thanks
Itlog? Di ko gets.
Weird ba? Hehe. Since nakuha ko yung unit at di na ako nakikidrive lang nasanay na ako sa ganun. Usually yung toes lang gamit ko sa accelerator at kapag braking toe mound naman. Sa long drive di naman sumasakit o nasanay na lang ako. Nagdrive ako dati total of 9 hours in 1/2 day pwet ko lang naman nairita hehe
Constant ako sa 8.2 km/l fc sa city driving. Which i think malakas.
Done with 1k PMS kanina using semi synthetic engine oil
Parang pumangit lalo hatak ng makina after ng PMS
