Results 4,591 to 4,600 of 8993
- Oct 2008
- 525
June 27th, 2014 05:28 AM #4591
June 27th, 2014 07:13 AM #4592
Guys penge advise,parang nagsisisi ako sa pagpapalagay ng magic tint sa buong windshield ko naachieve ko naman yung purpose ko ang magkaroon ng privacy ang problema e sa gabi nadidiliman ako minsan need ko mas bumagal kase im not sure sa dinadaanan ko if may tao ba o wala...nung isang araw muntik na ako makabangga ng motor pero sya talaga ang mali pero napakalapit na nya bagoko sya mapansin at makapagbreak ako buti na lang malakas kapit ng break natin.di lang ba ako sanay o talagang tanggalin ko na?pwede na ba DIY na yung pag alis nun?
Posted via Tsikot Mobile App
June 27th, 2014 08:45 AM #4593
Magic tint should be a light tint when its dark. The only problem for a magic tint is when its daylight sometimes it will reflect the light on your side mirrors. I have magic tint black on the sides but only light tint on the WS.
- Jan 2014
- 31
June 27th, 2014 08:54 AM #4594Hi Guys,
Mag ask lang po sana ako.. My nilalagay po ba kayo sa makina? like water sa radiator? sa wiper? kasi since binili namin yung vios namin nung january 2014 ni minsan hindi pa namin nilagyan ng kahit ano yung makina.. Were done with the 1st PMS going na sa 5kpms nyn.. Nag aalala lang ako kasi sobrang init yung panahon, yung tipong baka matuyuan. Ist car ko po kasi. Thank you in advance sa mga sasagut.
- Oct 2013
- 2,537
- Apr 2014
- 4
- Jan 2014
- 31
June 27th, 2014 10:39 AM #4597[QUOTE=JakeDGreat;2367253]Nako po! read the manual! hahaha.[/QUOTE
Binasa ko na po yung manual.. Wala naman nasabi.. or kasama na sa PMS un?
- Jan 2014
- 655
June 27th, 2014 10:41 AM #4598Meron po dun na diy maintenance after ng scheduled maintenance section ata. Nakalagay dun pagcheck sa engine compartment at mga tips na rin
- Sep 2013
- 83
June 27th, 2014 10:56 AM #4599If you lift / open your hood you will find the coolant reservoir and the wiper fluid reservoir/container. As long as they are in the correct quantity / level as prescribed on your user manual (which came when you purchased your car) then you are fine, else you need to top these up. For the exact location of these, you may read your owner's manual where you will find lots of info on what to regularly check to keep your car in good running condition. I bet you, you will never regret. Enjoy driving.
- Apr 2014
- 20
June 27th, 2014 12:58 PM #4600Guys panu b malalaman yung fc? How to compute po?
high idle RPM at engine start
