Page 11 of 74 FirstFirst ... 7891011121314152161 ... LastLast
Results 201 to 220 of 1463
    Oct 2015
    #201
    The old Innova 2.5L in a/t guise is relatively thirsty (around 7-8km/L in city) and one reason being was one had to punch the accelerator to start from standstill to overcome the lag and keep your spot in slow moving traffic. If the 2.8L gives good low end torque, coupled with the 6-speed a/t then it has a good chance of delivering par or better city FC versus the outgoing model (unless both engines idle for very long periods of time rather than move in stop and go traffic).
    In my case with the 2.4L Hilux m/t, so far I am getting somewhat better city FC versus when we had an Innova 2.5L J many years ago. (10km/L versus 9++km/L).
    The price is a game changer indeed; Our family was about to get dispose of our 2009 Innova G to get the new one and the pricing changes is now making us think twice. For our use, we don't need a 2.8L and would gladly spend for a 2.4L a/t if it was 100-150K less. Kaunting tumbling nalang, may Carnival na.
    Yup the old 2.5L was relatively thirsty but in stop and go in the city I didn't feel like I had to punch the accelerator (with the a/t) that much as the gear ratios were pretty good. Felt like the ratios were really made for in city traffic. Even better than the m/t. Its in the highways that the old 2.5L Innova felt anemic. I don't discount the possibility of the new 2.8L being more efficient in the city but with MM traffic being what it is right now, I wouldn't bet on it.
    The Carnival clearly looks like a better package but after owning 2 Korean cars I still doubt they'll be able to catch up in build quality (of parts) with this gen. I'm with you re: 2.4L, a much better match for the usage most people will have.
    #202
    This was the answer of the Innova's chief engineer on the decision to go for an all-2.8 lineup:
    Naturally, we asked Hiroki Nakajima, the chief engineer of the IMV platform, why local Innova gets the higher displacement engine. According to Nakajima, the hilly roads and our fondness of carrying extra passengers led to this decision and thus, the 2.8 engine made its way to our new Innovas which are being built in the Santa Rosa, Laguna plant.
    http://www.autoindustriya.com/featur...ta-innova.html
    Dec 2015
    #203
    This doesn't make sense... A 2.2 Korean engine doesn't have this issue.
    Jan 2016
    #204
    Quote Originally Posted by urbanmetal View Post
    The old 2.5 is quite sufficient already and the press release of the new 2GD (2.4 liter) declared more torque and HP (i think) coupled with the 6speed AT, should be enough already. My biggest concern with the 2.8 is the FC. Hope someone can give feedback as compared to the outgoing 2.5
    Sent from my SM-G530H using Tapatalk
    #205
    I've driven countless Innova diesels and share the same sentiment with all other Innova owners I've talked to - the Innova's 2.5 was sufficient even for a full load.
    The added power of the 2.4 would've been more than enough. 140+ horsepower for a people carrier is good enough to climb Baguio on a full load and overtake easily on two-lane provincial highways.
    My friend who's ex-Toyota says that it could be a supply issue for the 2.4, which is why they fitted the Innovas with 2.8s which were more available. Possible, but not exactly conclusive.
    Mar 2013
    #206
    I like the 2.8 though
    Oct 2015
    #207
    The 2.8L Fortuner's FC was 40% more than Toyota's claimed numbers in this Aussie review:
    Toyota Fortuner Review | CarAdvice
    Being a detuned version on narrower tires and possibly lighter body might help FC a bit. With the increase in power I hope they put in bigger brakes. The brakes in the previous gen were just good enough for the engine.
    #208
    One of my biggest gripes with their dropping in a 2.8L is that i'll be encountering cocky Innova drivers on the expressway.
    The 2.5L D4d G I use can do highway speeds and climb under a full load. But if you're talking about passing vehicles on a two lane strip at moderate speed then that's where it becomes wanting, most especially on a hot day where heat soak becomes apparent. Because of this I prefer using our family m/t GL Grandia for long trips over the a/t Innova.
    Mar 2013
    #209
    With a 2.8 they will be eating lots of cars and PPVs for breakfast.
    #210
    The new Innova would be a little over 1700 kg (old one was 1670 kg).
    At 100 hp/ton it's not exactly a lightweight. Could be faster 0-100 than most compacts but not by much. With steering, brakes, and handling that were not designed with speed in mind, any 1.5L subcompact or 1.6L compact can match an Innova's pace.
    #211
    Don't think Nakajima san had a "pocket rocket" in mind with the 2.8. :-D
    #212
    Quote Originally Posted by Wh1stl3r2 View Post
    Now that you pointed it out, I think it also boils down to maintenance. Since the Innovas we had were family car (family driver) affairs, the performance lag came about as the mileage climbed (egr clogging or turbo efficiency degrading perhaps?). It was decarbonized when they sent it to Toyota last year and I did notice an improvement afterwards.
    My main gripe with the Korean vehicles we've had (mid 00s to early 10's) is also the build and interior material quality. Reliability and engine performance is okay. Rode the '09 Carnival of my Uncle last week and the fit and finish of our 07 Vios which has been disassembled several times for flood repairs, with more mileage, still feels tighter.
    Surprised to see that the spec sheet indicates a 5-mt. Is this confirmed? Or they deliberately threw in a 5-mt to give us 2.4L owners a fighting chance? :rofl:
    Dec 2008
    #213
    I can only say that the 2.8GD in the Innova is a MAMAW. But I do not believe on his explanation why they didn't bring the 2.4GD. Probably a supply issue on 2.4GB or rather the 2.4GD Innova will only price slightly below the 2.8GD. That is why they opt to 2.8.
    #214
    Quote Originally Posted by veyron_27 View Post
    errr... what's a mamaw, po?
    Jan 2016
    #215
    I dont mind the engine being bigger as long as the FC is the same with the current 2.5
    Dec 2008
    #216
    Quote Originally Posted by watarii View Post
    I'm hoping would be the same as the old 2.5 or better. We will see in the next few months.
    Jan 2016
    #217
    Errr why is the diesel 2.4 in this site
    Toyota Innova 216 Price - Find Review, Images, Specs & Promo in Philippines | Carbay
    Ano ba talaga koya [emoji15]
    most carbay websites are inaccurate.
    spec sheet is here All You Need to Know About the 216 Toyota Innova (w/ Complete Specs) | ************ - Philippine Car News, Car Reviews, Car Features, Car Buyer's Guide and Car Prices.
    Mar 2013
    #219
    Am not only talking about peak HP which it already has a lot of. The torque curve for this 2.8 is sweet. For everyday driving and in gear pull this will make a world of difference.
    Jan 2016
    #220
    I would love to see the FC comparison 2KD vs 1GD including liters/hour at idle
2016 Toyota Innova
