Originally Posted by
bethaclaro
That headunit has a reset button sa lower right bottom part. It's small, really really small. Press that button for a minimum of five seconds using the pointed tip of a pen or a toothpick, then try turning it on again. If that doesn't work, it also came with a remote; try turning it off and on using that. And if that doesn't work, try taking the negative terminal of the battery off, then put it back (this does a reset too, I think) then try turning the headunit on again. If that still doesn't work, it's time you bring it back to the casa. Under warranty pa yan.
Actually, it might be easier to just have them fix it. :D hehehe
