Results 641 to 650 of 2050
May 23rd, 2014 12:14 AM #641
- Feb 2014
- 47
May 23rd, 2014 09:07 AM #642Normal din po ba na tumutunog pag magfull right turn?or full turn left?kasi bago?
Posted via Tsikot Mobile App
May 23rd, 2014 09:38 AM #643
anong tunog? depende sa tunog yan.
but most commonly kung lagatok, hindi. kung ingay at palag ng tires, yes.
- Feb 2014
- 47
May 23rd, 2014 08:47 PM #644
May 24th, 2014 12:10 AM #645
gusto sana kita tulungan pare, kaso malayo ka ata. kung dito ka lang sa south, pwede nating tignan at hingan ng second opinion sa kung saan mo man gusto.
- Dec 2008
- 16
May 24th, 2014 05:08 AM #646regarding warraty.
sinu sa inyo nag pa tanggal ng sensor para makanood ng videos while driving?
another is kung meron na ba dito nag padagdag ng additional 2 speaker sa likod?
- any void of warranty sa dalawa na yan? thanks
- May 2014
- 4
May 24th, 2014 05:16 AM #647Ala po ba nakaka alam na may mura buffing? Haaaay.... Ok lang good morning, time to sleep... :-)
- Aug 2012
- 2,767
May 24th, 2014 10:05 AM #648regarding warranty..
Aftermarket equipment added to your vehicle does not automatically void a vehicle manufacturer's original warranty unless:
- The warranty clearly states that
- It can be proven that the aftermarket add-ons were the direct cause of the problem
What this means?
A vehicle manufacturer can’t void your warranty simply because you installed aftermarket car equipment unless it can prove that the equipment led to the malfunction for which you’re claiming warranty coverage.
- Jun 2005
- 3,774
May 24th, 2014 12:24 PM #649
- Aug 2012
- 2,767
May 24th, 2014 02:36 PM #650that does not make any sense.
for example, if i am claiming warranty for engine problem due to faulty spark plug or radiator problem due to faulty thermostat, my added rear speakers has no relation to that.
or are you saying they will find a connection between the rear speakers and the faulty spark plug; or a connection between rear speakers and the faulty thermostat?
just asking.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
