Results 671 to 680 of 691
- Dec 2012
- 7
February 24th, 2015 08:58 PM #671Ask ko lang kung anong tire size ang kasya sa stock height ng vitara? Thanks!
- Apr 2014
- 13
March 4th, 2015 09:13 PM #672
BANNED BANNED BANNED
- Jul 2010
- 131
- May 2015
- 5
May 26th, 2015 01:10 PM #674Stock Vitara setup would allow us much as 235/75r15 or 29" Tires without rubbing. You can fit 30x9.5r15 but it will rub against the plastic bumper. You can have it skillfully cut by your seasoned latero and the cut would be negligible.
Boss,
Pag 2" lift lang po marami pong paraan.
The pricey path:
1) Ironman offers a 2" kit comprising of coils and springs only. Set is around 35K.
2) Old Man Emu also has this kit for 50K.
The Budget path:
(((IF You want a suspension lift))
1) You can simply go for 2" coil spacers (rubber or aluminum). They will increase ride height but will not give any extra articulation the way longer coils will.
2) You will need to put 2" extension brackets on your stock front struts (front shock absorbers) to compensate for the 2" additional height of the coils.
3) You will also need to get longer rear shock absorbers. There are a lot of affordable options for this. Stock shocks have a length of 19". So you need to get 21" or 22" long shocks. KYB Premium is the most affordable.
4) You will also need to adjust your camber alignments so you need to get camber bolts.
Estimated cost: 15K
Another option is a 2" Body Lift only. This does not alter any of your suspension geometry. All it does is lift your car's body 2" above the chassis giving a visual lift only. These are normally done to fit larger tires to prevent them from rubbing against the fender walls. But it gives the illusion of a lift.
Estimated cost: 6K
Hope this helps...
Boss,
The pricey path:
The Budget path:
Estimated cost: 15K
Estimated cost: 6K
Hope this helps...
- May 2015
- 5
May 26th, 2015 01:13 PM #675Vitara parts are not hard to come by. They are only expensive compared to Toyota parts. But they are easily sourceable.
FC for a well maintained stock would be 12kms/ltr city driving and 16kms/lts highway... FC for Modified rigs with chunky tires would be a fraction of those numbers
- May 2015
- 5
May 26th, 2015 01:17 PM #676
- Mar 2005
- 40
May 28th, 2015 09:35 AM #677
- May 2015
- 5
May 28th, 2015 03:40 PM #678Hey Man,
For the ARB kit, you can go to RATS4x4 along Katipunan.
For the Ironman kit, you can go to MONSTERWORX Steel Fabrications in c5 Extension near SM Sucat and look for Raymond Rivera...
If you wish to ask for the cheaper alternative I posted in the previous messages, send me a PM as there are many things to consider when you go that way.
January 21st, 2016 08:33 AM #679
Sir zooker possible ba iconvert sa diesel engine ang vitara while maintaining its 4x4? I understand that the Mazda RF engine is compatible, but how about the transmission? Thanks in advance!
- Mar 2016
- 8
March 31st, 2016 10:55 PM #680Meron kayong alam na head unit na touch screed with nav para sa suzuki grand vitara 2015? Hm? Tnx
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
