Results 661 to 670 of 691
- Nov 2013
- 2
November 28th, 2013 01:54 PM #661Good day mga sirs,
Ask lang po sana ako ng opinion nyo regarding sa problem ko sa vitara escudo AT (sidekick). Ang nging problem po nung sasakyan is yung crank shaft pulley need na pong palitan kasi nag wear-off n ung rubber nya in between plates. So last week after sya napalitan kila Mang Rod (Filmars) ng crank shaft pulley at the same time inayos na rin daw yung timing, nung na drive ko na, napansin ko na parang biglang mag slowdown even if nkakatakbo na ko ng mabilis. Parang bigla na lang nhihirapang mag accelerate. Bago napalitan yung pulley, oks nman yung acceleration nya, so bumalik ulit ako sa Filmars at inadjust ni Mang Rod ung acceleration cable, sabi nya yun lng daw ang pwede nya mgawa dun since AT daw kasi. After ng adjustment, ng drive ulit ako at gnun pa rin ang result nya. May kinalaman kaya yung timing sa pgbago ng takbo nya? Any inputs po regarding my problem mga sir? Thanks!
- Nov 2013
- 2
November 28th, 2013 01:55 PM #662Good day mga sirs,
- Aug 2012
- 6
January 16th, 2014 04:14 AM #663Good morning, tanong ko lang how much ang water pump and timing kit for 96 vitara g16b? nasiraan ng water pump and isasabay na ang pag palit ng timing belt. :D
- Aug 2012
- 6
- Mar 2014
- 1
March 28th, 2014 04:02 AM #665good day mga sir hingi lang po sana ako ng input kung anung possible na tama nung vitara JLX 96 model namin, we purchased the car as 2nd hand at interior and body is flawless reason why we did not hesitate to buy the car . when we did a test drive it was running good,as as we brought it home we noticed that the water from the radiator was almost empty the engine is overheating we brought it to the mechanic and was informed that it is a loose compression issue and the water is also mixing in with the fuel,they had to do a top overhaul change gaskets change radiator as well they also had the engine waorked on a machine shop,after 4 days they were able to accomplish the repair but there still issues on the engine the 3rd cylinder from the front is not working,we had it checked again at reys electrical found out that all the plug wires has electricity,also one issue is when we are driving uphill wlang hatak sa 2nd gear and the following gears kahit nakabwelo na,we need to stay at 1st gear para lang makaakyat,hingi lang po sana ko ng input kung anu po kayang reason kung bakit hindi gumagana yung 3rd cylinder at bakit ayaw humatak sa 2nd gear pag akyatan na,im planning to change the spark plugs muna but im not sure if it will fix it,anu nga po palang spark plug ang bibilhin ko TIA mga master NOOB kasi ako sa sasakyan
- Dec 2012
- 20
September 10th, 2014 10:30 AM #666I am planning to buy a Suzuki Vitara JLX MT 1996 * Php 135,000
Seems ok ang condition ng interior at exterior.
Scheduled for test drive tom...
What do you think of the price considering it is already an old vehicle.
Thanks,
Edd
- Sep 2011
- 14
September 22nd, 2014 12:30 PM #667sir swertehan ang pagkuha ng vitara sa panahon ngayon, kung kakilala mo buyer mas mabuti para malaman mo totoong history ng bibilin mo. Pero kapag naka-tiyempo ka ng maayos pa na vitara, you'll be satisfied sa performance. Almost 4 years na sa akin nakuhang kong vit at napaka-low maintenance parang hindi nasisira, minor lang mga pinaayos ko. Nagamit ko na sa mga off road at long distance travel like Baler, Bolinao,... Hindi naman ako nagkaproblema sa lahat ng travel ko.
December 29th, 2014 09:04 AM #668
Hi Guys,
Im planning to get a Vitara first Gen as a first car. May ma recommend ba kaung unit that is within 120k Budget. Metro Manila po. Salamat
- Dec 2014
- 1
- Dec 2014
- 1
December 30th, 2014 01:00 AM #670Hi Bro, How much yang auto mo? And san location mo? Email mo ko sa pjmdimailig*gmail.com
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
