Results 411 to 420 of 691
September 23rd, 2010 03:36 PM #411
naku overheat, well hopefully walang nasirang gasket at nag warp na head. better have it checked by your trusted mechanic just to be sure.
also check your ATF, if it smells burnt have it changed.
- Dec 2008
- 18
September 23rd, 2010 11:14 PM #412*impulzz, Salamat sa reply sir
bad news, nag'overheat na naman knina.. pinagtataka ko lng kse puno pa naman ung plastic container ng engine coolant, ung radiator lng mismo ang nawawalan ng tubig. cge sir, ipa'check ko na agad to bukas.
tanong ko lng sir, san ba mas advisable? nka'On or nka'Off ang OD?
September 26th, 2010 01:10 AM #413
malamang naubusan ka ulit ng tubig kasi nung kinargahan may hangin sa loob, tapos sinara agad rad cap. when that happens pag uminit yung airpocket mas mabilis maubos tubig. you have to "burp" the system.
what you can do is while the engine is running get a wet rag and slowly open the rad cap, then pour in your coolant mix. have someone rev the engine a little. para umikot yung coolant and air pockets can escape.
as for OD. leave it on so it can shift to OD or 4th gear in long drives.
nagamit ko lang OD off nung nasa tanay ako puro paakyat so para hindi mag gear hunting masyado, off ko sya, but when i reached the parts na pababa na ON na ulit.
- Dec 2008
- 18
September 26th, 2010 01:47 AM #414Wow! Salamat sa advice at info sir impulzz!
Pina'check ko na knina.. may leak na ung upper part ng radiator (ung plastic na part). Sa tingin ko, dulot un ng pag'off ko sa OD when I travelled * 60-80kmph on a long trip. Pansin ko kse noon parang nag'hihingalo ang makina, as compared sa nka'on ang OD na ok naman kahit 80kmph na.
Salamat sir
- Jun 2008
- 24
September 28th, 2010 06:43 PM #416ok na, pinon oil seal lang pala.. ayun wala na tagas ahehe... regarding overheat, pa check nyo po agad sir malaki gastos yan pag kumatok makina, hindi pa naman ganun kadali humanap ng local g16b...
- Jul 2010
- 109
September 29th, 2010 07:04 PM #418Hi guys,
Need help. Parang grounded yata yung wiring ng hand brake indicator sa dashboard ko. Tuwing malulubak or mag sharp curve, umiilaw yung indicator for a moment tapos mamamatay din ulit. Feeling ko nag coconnect siya sa ground kapag naiipit or something kaya umiilaw pag nalulubak. Saan ko ba pwede tignan yung connection na yun? Feeling ko kasi madali lang siya ayusin. Hindi ko lang alam where to start.
- Jan 2010
- 3
September 30th, 2010 02:00 PM #419Guys,
May alam ba kayo na nagaayos ng speedometer? dkse gumagana yung ODO meter ko pero yung needle and trip meter is ok. Makati and marikina area sana. D daw kaya gawin nila filmars.
*kenn.garcia- Try mo rin bro sa reys electrical para wala na hassle sayo. 15th ave. QC. Ako rin may problem sa electrical ko, pumuputok yung fuse ng signal light. Napa check ko na yung linya sa iba pero ok naman lahat. Need time lang para ipa check ulit.
*impulzz- Try mo bro sa filmars, mga 2k aabutin kung palit lahat- brake fluid, ATf and transfer gear oil. Parts and labor na yun.
October 1st, 2010 01:49 AM #420
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
