Page 42 of 70 FirstFirst ... 3238394041424344454652 ... LastLast
Results 411 to 420 of 691
    Jan 2003
    #411
    naku overheat, well hopefully walang nasirang gasket at nag warp na head. better have it checked by your trusted mechanic just to be sure.
    also check your ATF, if it smells burnt have it changed.
    Dec 2008
    #412
    *impulzz, Salamat sa reply sir
    bad news, nag'overheat na naman knina.. pinagtataka ko lng kse puno pa naman ung plastic container ng engine coolant, ung radiator lng mismo ang nawawalan ng tubig. cge sir, ipa'check ko na agad to bukas.
    tanong ko lng sir, san ba mas advisable? nka'On or nka'Off ang OD?
    Jan 2003
    #413
    Quote Originally Posted by drumbeater79 View Post
    malamang naubusan ka ulit ng tubig kasi nung kinargahan may hangin sa loob, tapos sinara agad rad cap. when that happens pag uminit yung airpocket mas mabilis maubos tubig. you have to "burp" the system.
    what you can do is while the engine is running get a wet rag and slowly open the rad cap, then pour in your coolant mix. have someone rev the engine a little. para umikot yung coolant and air pockets can escape.
    as for OD. leave it on so it can shift to OD or 4th gear in long drives.
    nagamit ko lang OD off nung nasa tanay ako puro paakyat so para hindi mag gear hunting masyado, off ko sya, but when i reached the parts na pababa na ON na ulit.
    Dec 2008
    #414
    Wow! Salamat sa advice at info sir impulzz!
    Pina'check ko na knina.. may leak na ung upper part ng radiator (ung plastic na part). Sa tingin ko, dulot un ng pag'off ko sa OD when I travelled * 60-80kmph on a long trip. Pansin ko kse noon parang nag'hihingalo ang makina, as compared sa nka'on ang OD na ok naman kahit 80kmph na.
    Salamat sir
    Jan 2003
    #415
    hirap na humanap ng plastic top ng vitara.
    Jun 2008
    #416
    ok na, pinon oil seal lang pala.. ayun wala na tagas ahehe... regarding overheat, pa check nyo po agad sir malaki gastos yan pag kumatok makina, hindi pa naman ganun kadali humanap ng local g16b...
    Jan 2003
    #417
    magkano inabot sir??? nag palit ka na din ng gear oil?
    Jul 2010
    #418
    Hi guys,
    Need help. Parang grounded yata yung wiring ng hand brake indicator sa dashboard ko. Tuwing malulubak or mag sharp curve, umiilaw yung indicator for a moment tapos mamamatay din ulit. Feeling ko nag coconnect siya sa ground kapag naiipit or something kaya umiilaw pag nalulubak. Saan ko ba pwede tignan yung connection na yun? Feeling ko kasi madali lang siya ayusin. Hindi ko lang alam where to start.
    Jan 2010
    #419
    Guys,
    May alam ba kayo na nagaayos ng speedometer? dkse gumagana yung ODO meter ko pero yung needle and trip meter is ok. Makati and marikina area sana. D daw kaya gawin nila filmars.
    *kenn.garcia- Try mo rin bro sa reys electrical para wala na hassle sayo. 15th ave. QC. Ako rin may problem sa electrical ko, pumuputok yung fuse ng signal light. Napa check ko na yung linya sa iba pero ok naman lahat. Need time lang para ipa check ulit.
    *impulzz- Try mo bro sa filmars, mga 2k aabutin kung palit lahat- brake fluid, ATf and transfer gear oil. Parts and labor na yun.
    Jan 2003
    #420
    Quote Originally Posted by kenn.garcia View Post
    Hi guys,
    baka mababa brake fluid level kaya yun sensor pag nalulubak nag-activate.
GEN I Suzuki Vitara 88-up [merged]
