Results 401 to 410 of 691
September 21st, 2010 01:02 PM #401
sa cubao DKC name ng store, along p. tuazon lampas 15th ave. bago mag 20th ave.
3500 yung dunlop 703 brand new, tawaran mo na lang yung tingga, free naman labor ng balancing.
- Jul 2009
- 54
September 21st, 2010 06:19 PM #402hi sirs,
share ko lang, diba i used to have a very slow moving aux/condenser fan and i thought the culprit was the fan carbon motor bushings.
so i brought my vit 96 matic to Robinaire Car Aircon near Cainta Junction, as soon as i parked my vit, 3 mechanics immediately checked my aux fan.
first look palang na-suspect na nila na yung electrical yung problem. so they traced the connections,fuses, and connectivity of the wires to the aux fan and saw that the positive terminal line had no power. they traced the problem to the aircon relay near the battery bay (yung black na rubbery yung cover near the AC fuse).
they replaced that and immediately my fan worked na uli, very fast na uli yung ikot!300php was all it cost (tama lang ba yung price?) and i gave them 20php tip pang-yosi hehe
btw, pinacheck ko if R-134A ba yung aircon ng 96 vit matic ko, isang look palang nila sa service charge valve ng aircon system ko, alam na nila kaagad na R-134A nga yung aircon ko. i asked if i need to have the freon re-charged na, hinawakan nila yung vent ng aircon ko, sabi di pa raw kailangan kasi malamig pa yung singaw and if gusto ko raw, pa-cleaning nalang para mas lumamig pa. i'm happy sa honesty nila and quick, no-nonsense approach sa pag-ayos ng aux fan ng vit ko
i highly recommend this shop for those living near our area.
- Jul 2009
- 54
September 21st, 2010 06:30 PM #403sir big bert, musta po feedback niyo sa dunlop 703? all terrain tires po ba ito or highway terrain? anong size po kinuha niyo, 215/75r15? thanks
September 21st, 2010 09:35 PM #404
buti naayos n aux fan mo.
dunlop 703 highway tires, yup 215/75r15 gamit ko ngayon. ok naman tahimik ang takbo, makapit naman for everyday use, di nga lang kasing porma ng mickey thompson ATLast edited by impulzz; September 21st, 2010 at 09:39 PM.
- Jun 2008
- 24
September 22nd, 2010 01:53 AM #405thanks sir bigbert for the suggestion sa goma i will check nalang.. by the way mkhang may bago nanaman ako problem, kanina lang nakita ko may tagas sa differential yung bilog na mukhang pakwan basa yung ilalim na portion ano kaya yun?
September 22nd, 2010 02:17 AM #406
yung differential. baka yung gasket may punit na. pa under wash mo para makita kung saan talaga galing tagas.
- Jul 2010
- 109
September 22nd, 2010 02:19 PM #407I've read in another thread that one of the common issues with Vitara's is the steering pump and the whole mechanism.
How exactly do you know kung may problem with it? Yung saken po kasi palaging basa yung buong block sa steering pati yung hose na galing sa ATF reservoir. Hindi naman ganun kalakas magbawas yung ATF. Yung steering naman, hindi siya super bigat pero medyo malayo din sa gaan ng ibang power steering na kotse.
What do you guys think? May problem kaya sa steering ko o normal lang yun for 4x4's?
September 22nd, 2010 03:03 PM #408
due to the age of our vits, yung mga hoses at clamps sa PS pump and reservoir nag kaka roon ng konting "pawis/libag ng Steering Fluid". yung sa akin 3 years na nililinis ko pag nakita kong libag na ulit and i always check the fluid level. di naman nagbabawas ng fluid pero bumabalik yung "pawis sa hoses". also check the clamps kung lumuwag.
yung bigat ng manibela depende rin sa tire pressure, size ng gulong, alignment.
as for ....normal ba sa 4x4??? nope, hindi lang sa 4x4 yan. even my 94 hiace nagkakaganun, pati yung lancer ng byenan ko. pero every time i check the fluid level walang bawas.
what you can do is buy degreaser, clean the area of the PS tank at Pump, to see where the leak is coming from.Last edited by impulzz; September 22nd, 2010 at 03:18 PM.
- Jun 2008
- 24
September 22nd, 2010 10:40 PM #409*differential. kinapa ko sya kanina pinaka malangis banda sa ugtungan ng pinon shaft at joint, pasilip ko nalang sa mekanik para sure sa part, oil seal lang siguro..
- Dec 2008
- 18
September 23rd, 2010 12:48 AM #410Sir Impulzz, ano po opinion mo sa sitwasyon ko.
Ganito kase nangyari:
Medyo malayo binyahe ko for the past couple of days.. tapos I'm running 60-80 kmph on clear and long highways. Pansin ko lng after my trip was na'pindot ko pala ung parang may switch dun sa gear stick ko. Nakita ko kse sa dashboard na may nka'ilaw na OD na sign. All the while pala sa trip ko, nka'ilaw na ung sign na un sa dashboard ko which is di naman un nka'ilaw on my usual trips. Kinabukasan after my trip, mga 2kms pa lng galing sa bahay, biglang umusok na ung hood ko. Yun pala, nag'overheat na ang makina. Nagulat ako kse 2 weeks b4 my trip, eh puno pa ung radiator tsaka ung plastic container ng tubig at engine coolant. All I did was pinuno ko ulit ung plastic container at radiator ng engine coolant tsaka tubig. Ngayn naman, medyo nangangamoy engine coolant na ang makina tsaka ung loob ng vit ko sa tuwing ginagamit ko ito.
Ano po opinion nyo dun sir? Salamat po
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
