Results 41 to 50 of 50
January 8th, 2016 10:37 AM #41
^ ok na iyong mga engine support niya bos. napalitan ko na iyong mga iyon 2 years ago and so far they're still good
- 54,230
January 8th, 2016 10:41 AM #42
BANNED BANNED BANNED
- Jan 2015
- 4,580
January 8th, 2016 11:06 AM #43
January 8th, 2016 11:52 AM #44
Symptoms of engine support should be vibration especially in cold starting.
January 8th, 2016 11:56 AM #45
Engine support is such a common problem of the FD that if that was the culprit, madali lang ayusin and any repair shop would know to look at that first.
- Apr 2008
- 48
January 8th, 2016 12:44 PM #46in my case ganun din, may kalampag din when driving slow then hit a humps. initially i thought it was suspension and ball joints and i replaced them immediately with my trusted mechanic. pero andun pa din yung kalampag. Then i went to suspension specialist and found out my engine mounts are broken. i ask kung ilan dapat palitan, sabi skin yung 4 daw. pero di ako naniwala so ng second opinion ako sa gas station only to found out that only 1 is broken. so after mapalitan yung mount nawala na rin annoying kalampag.
- 54,230
January 8th, 2016 12:46 PM #47one problem in diagnosing via the internet, is the difficulty or in-accuracy of the description of the problem... sound... etc.
January 13th, 2016 01:27 PM #48
i finally licked my problem.
apparently it was just a case of re-tightening the steering mounting gearbox bolts. now everything is fine and dandy once again
February 1st, 2016 04:28 AM #49
February 1st, 2016 11:57 PM #50
Bro sorry just read this now. Replied to your PM as well.
Just to add to what I told you, while Cruven Makati was able to remedy my problem, their diagnosis was much much quicker simply because I told them where to look. With that, I'd advise you to try to single out the problem and be as detailed when describing when your problems occur, and be sure to make it show on a test drive. Be more observant when you drive your car on a daily basis so you can tell them exactly where the sound seems to be coming from.
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
