Page 2 of 2 FirstFirst 12
Results 21 to 40 of 50
    Maganda pala talaga sa Cruven
    Alam kagad nila yung gagawin when I pointed out that it was a brake issue. I'm not sure if other shops would've been able to diagnose it correctly and weld the brake pad edges as a solution. Yung ibang shops nga parang wala namang welding machine though of course baka di ko lang nakikitang ginagamit.
    To be fair though, if I didn't tell them of my observations with the brakes, I'm sure they would've thought that the suspension was the culprit as well. Inexplain ko na kagad that I've changed all my suspension bits so they should look elsewhere.
    it really is of great help, bro, if the owner had the car sense kasi most mechanics defer to the owner or driver's diagnosis.
    May 2009
    bakit hindi shims/anti-rattle clip brader?
    sabagay, cheaper na rin yung welding. i suppose. kaso iniisip ko lang yung adhesive sa brake lining baka nagbago ang ugali sa tindi ng init ng welding. or some other effects.
    Jan 2009
    Quote Originally Posted by miked View Post
    Oo, ang clip fills the gap/void between the brake pad & caliper bracket/support. Kapag wala ito at ang shim, may ingay na maririnig sa rough cement/asphalt road. Kadalasan, di ito naibabalik ng mga negligent na mekaniko kapag nagpapalit ng brake pads, & they usually say na, "okey lang 'yan kahit wala".
    Hard to say but it could be your tie rod and ball joints. Baka kailangang i-repack?
    Jan 2016
    Parang CRUNK sound?
    Pacheck mo sir tie rod, rack end and ball joint
    Quote Originally Posted by TON_ton View Post
    Parang CRUNK sound?
    i already replaced my tie rods, rack ends, stab link, shock mounts, rubber stoppers, front shocks, and shock boots pero iyong ball joints ang hindi pa. will have them checked later
    thanks!
    Jan 2016
    thanks!
    Sure na ball joint yan sir [emoji106]
    Symptoms of engine support should be vibration especially in cold starting.
    Engine support is such a common problem of the FD that if that was the culprit, madali lang ayusin and any repair shop would know to look at that first.
Unknown Kalampag (Not Suspension-related)
