Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 93
    #31
    Quote Originally Posted by suysuy View Post
    Naghahanap ako ngayon ng replacement bushings. If wala akong makita, buong assembly nalang. May cruven dito sa davao. Doon first stop ko.
    Sent from my SM-A605G using Tapatalk
    may mga nagsabi, na bushings-only replacement, don't last long. better entire assembly replacement, daw.
    Apr 2009
    #32
    the whole entire OEM A-arm assembly is the best route but expensive. If your A-arm is also with a Shaft Link Kit, better replace it as well especially if you've been using your Sorento on rough roads..
    Check also the your Stab Links, Stabilizer bar bushings, etc. You have to change them too if they have seen better days...
    Mar 2007
    #33
    Got my original bushings from korea. Replaced old bushings already. But there’s a new problem.
    Car drives straight. But upon braking, steering wheel slightly turns to the left (11 oclock position) and the car pulls to the right in proportion to the steering wheel movement to the left.
    WHAT COULD BE WRONG?
    Jan 2008
    #34
    Baka di pantay ang preno.. need to lubricate caliper pins
    Mar 2007
    #35
    How to check for this? This car is not equipped with abs. Should I just brake hard and observe which tire locks up first?
    Apr 2009
    #36
    It could be that your front brake calipers are sticking up and needs servicing (cleaning and replacement of caliper rubber brake seals, etc) if still feasible. Otherwise, If the caliper piston &/or cylinder are severely pitted, you have to change the whole assembly... Time to change your brake fluid too
    #37
    Quote Originally Posted by LN106G View Post
    caliper guide pins bro...
    Jan 2008
    #38
    No. Maybe need servicing ng calipers mo..
    Mar 2007
    #39
    Update: under full braking force, left front wheel locks up instantly while the right does not.
    Jan 2008
    #40
    There you go... need talaga servicing ng calipers mo.. include mo na cleaning ng buong caliper including the piston.
Steering wheel alignment issue
