Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 61 to 70 of 93
    Jan 2019
    #61
    Mukhang may mali sa pagkabit ng rack and pinion mo. Hindi nga centered yan kaya bitin sa kabilang side ang turn.
    Sent from my SM-G965F using Tapatalk
    Applicable kaya tong video na to sa lahat ng rack and pinion mga sir?
    How To Center A Rack and Pinion - YouTube
    #62
    rack doesn't need centering. its pre aligned for the steeeing shaft.
    so, when the brand new rack is purchased, it is already pre-aligned and "locked to the center position" ?
    thus, the mekanikos have to work the installation and alignment, without moving that setting?
    May 2011
    #63
    The SRS or airbag clockspring might not have been centered when the rack and pinion was replaced limiting the number of turns in one direction
    #64
    Quote Originally Posted by suysuy View Post
    Genuine kia bushings. The whole arm costs an arm and leg. Baka ndi maayos sayang lang pera. There might be something that is causing this. Disc brakes and calipers were already checked. So hindi siya issue sa brakes.
    There is something loose when you apply the brakes, it changes the steering angle or the suspension shifts. But im already running out of ideas kung alin sa ilalim ang need pang tingnan
    Uneven brake pressure almost always is caused by the ABS Pump. Try mo rin ipa flush muna baka makuha dun. Usually dahil sa maduming fluid.
    Aug 2013
    #65
    shocks sir.
    kung mas malambot isang side, kapag nag brake, pag shift ng weight ng sasakyan sa harap, liliko magisa.
    baka lang naman, ganito kasi na experience ko sa hilux, kaso naka negative camber ako sa harap (-1)
    na correct siya nung nagpalit ako ng shocks.
    Mar 2007
    #66
    Quote Originally Posted by innova2013 View Post
    shocks sir.
    Hmmm pwede. Stock shocks pa ako. Weird lang yung manibela papuntang kaliwa pero yung nguso ng car ko pa kanan. Opposite yung direction.
    Aug 2013
    #67
    try mo sir magpa toe correction habang nakasakay ka sa driver side.
    kadalasan P200 to P400 ang singil sa toe correction.
    tignan mo sir kung mawawala yung problem mo.
    kaya siguro opposite direction kasi nag correct ka na while braking to straighten the car sir.
    #68
    yes sir, steering rack is mounted on the subframe(crossmember) without any adjustment. the only adjustment is the tie rods but this doesnt affect the steering angle/limit if done right.
    #69
    which shop are you going to for suspension alignment? are you in metro manila? there are several shops that use hunter alignment systems that might diagnose your vehicle alignment better.
    #70
    meron malapit sa pasig bro?
Steering wheel alignment issue
