Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 93
    Jan 2019
    #61
    Mukhang may mali sa pagkabit ng rack and pinion mo. Hindi nga centered yan kaya bitin sa kabilang side ang turn.
    Sent from my SM-G965F using Tapatalk
    Applicable kaya tong video na to sa lahat ng rack and pinion mga sir?
    How To Center A Rack and Pinion - YouTube
    #62
    rack doesn't need centering. its pre aligned for the steeeing shaft.
    so, when the brand new rack is purchased, it is already pre-aligned and "locked to the center position" ?
    thus, the mekanikos have to work the installation and alignment, without moving that setting?
    May 2011
    #63
    The SRS or airbag clockspring might not have been centered when the rack and pinion was replaced limiting the number of turns in one direction
    #64
    Quote Originally Posted by suysuy View Post
    Genuine kia bushings. The whole arm costs an arm and leg. Baka ndi maayos sayang lang pera. There might be something that is causing this. Disc brakes and calipers were already checked. So hindi siya issue sa brakes.
    There is something loose when you apply the brakes, it changes the steering angle or the suspension shifts. But im already running out of ideas kung alin sa ilalim ang need pang tingnan
    Uneven brake pressure almost always is caused by the ABS Pump. Try mo rin ipa flush muna baka makuha dun. Usually dahil sa maduming fluid.
    Aug 2013
    #65
    shocks sir.
    kung mas malambot isang side, kapag nag brake, pag shift ng weight ng sasakyan sa harap, liliko magisa.
    baka lang naman, ganito kasi na experience ko sa hilux, kaso naka negative camber ako sa harap (-1)
    na correct siya nung nagpalit ako ng shocks.
    Mar 2007
    #66
    Quote Originally Posted by innova2013 View Post
    shocks sir.
    Hmmm pwede. Stock shocks pa ako. Weird lang yung manibela papuntang kaliwa pero yung nguso ng car ko pa kanan. Opposite yung direction.
    Aug 2013
    #67
    try mo sir magpa toe correction habang nakasakay ka sa driver side.
    kadalasan P200 to P400 ang singil sa toe correction.
    tignan mo sir kung mawawala yung problem mo.
    kaya siguro opposite direction kasi nag correct ka na while braking to straighten the car sir.
    yes sir, steering rack is mounted on the subframe(crossmember) without any adjustment. the only adjustment is the tie rods but this doesnt affect the steering angle/limit if done right.
    which shop are you going to for suspension alignment? are you in metro manila? there are several shops that use hunter alignment systems that might diagnose your vehicle alignment better.
    #70
    meron malapit sa pasig bro?
    medyo malayo sa pasig.. malapit sa amin though.
    bridgestone pasig pala
    denise levertov quotes
    #73
    Robust Trading (Bridgestone, Aircon, Alignment, Electrical & Automotive Service)
    5.0
    (7) · Tire shop
    15 Shaw Blvd
    +63 2 245 1600
    Open ⋅ Closes 5:30 p.m.
    Bridgestone Pasig - Tire Wizard Depot, Inc.
    4.3
    (7) · Auto parts store
    60 Ortigas Ave Ext
    +63 2 656 1998
    Open ⋅ Closes 5 p.m.
    bro 2 lumabas sa maps, san dito? thanks!
    5.0
    (7) · Tire shop
    15 Shaw Blvd
    +63 2 245 1600
    4.3
    60 Ortigas Ave Ext
    +63 2 656 1998
    yun nasa itaas. 15 shaw blvd
    though i think most Bridgestone and Goodyear use Hunter. .
    #75
    check ko yun 2 goodyear na tumira alignment ko. medyo sablay kasi last 2 alignment ko. lagi di pantay yun wheel and parang tinatamad mechanic.
    tutok bro.. baka mali yun niselect na vehicle sa software. yun elantra ko md series. hindi alam nung technician. even with steering lash dapat ok yan.
    Wheel Alignment with WinAlign Software by Hunter Engineering - YouTube
    #77
    naiinis nga ako kasi vios 2008 ang nilalagay nila bro
    sabi ko wala ba yaris/vious 2005-06 or any cars na malapit man lang sa totoong specs ng auto ko, sagot nila yun lang daw pag vios nila O_o
    pag oil change ko kalikutin ko yun hunter sa tyre shop maybe within 2 weeks. tignan ko yun library ng hunter for vios. for hyundai completo lahat. ako pa yun pumili.
    Nov 2017
    #79
    *stock
    newbie sa site na ito.... ask ko lang may alam kaba sa good shop (steering wheel alignment) somewhere Sta Rosa Laguna?
    Quote Originally Posted by Relly Luna View Post
    *stock
    hows your tire pressures?
    pacheck ckeck mo suspension baka kailangan adjustment. steering is the last step normally
    Bridgestone Santa rosa.. note the guarantee length..
    Minerva tyre gallery - read the reviews
Steering wheel alignment issue
