Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 93
    Mar 2007
    #41
    There you go... need talaga servicing ng calipers mo.. include mo na cleaning ng buong caliper including the piston.
    Sana nga ito yung culprit. One problem solved leads to another problem. Medyo malaki na yung gastos ko. Magkano pa ba service ng brakes?
    Jun 2018
    #42
    *suysuy
    Na solve na ba issue mo?
    I have the same concern on my city.
    #43
    Usually the mechanics compensate through the rack end for camber alignment issues. May lock nut yun to prevent it from coming loose and making the steering from being misaligned. Maybe the nut is stripped or could it be the mechanic forgot to tighten the nut?
    Jan 2019
    #44
    Good day mga sir.
    Di pa ko makacreate ng new thread kaya dito na lang ako magtatanong, related issue naman.
    Yong corolla ko po kasi kulang yong turn radius niya pag right turn, left okay lang (or sobra?).
    Pag lumiliko tuloy ako kanan, bitin na, need ko umatras unlike before.
    Napa-align ko na wheel ko, computerized, so okay alignment.
    Any recommendation to check mga boss?
    Quote Originally Posted by Ronpascual View Post
    Good day mga sir.
    1986 corolla?
    Jan 2019
    #46
    1986 corolla?
    1997 sir.
    Actually sir nagpapalit pala ko ng rack and pinion. Tapos pinaalign ko naman.
    okay naman if driving, yon lang parking dahil kulang sa liko kanan, nabibitin.
    1997 sir.
    bro watch the video.. there is a rack limiter. baka magkaiba yun nakalagay..
    Jan 2019
    #48
    Thanks sir. May video pala. di ko Nakita nung una.
    brand new pa naman yong rack and pinion na binili ko, although Taiwan.
    wala na kaya ibang cause sir? problema kasi mas maraming turn steering wheel sa kaliwa kesa sa kanan.
    Jan 2019
    #49
    Tsaka sir, napansin ko magkaiba yong haba ng nakalabas na tie rod thread sa left and right part. Possible bang cause ito?
    Feb 2005
    #50
    if you notice in the video magkaiba talaga turning degrees ng right and left wheels, so I guess hanggang dun na lang talaga turning point ng wheels mo? watch mo raw yung next video nya gagawa sya ng custom kits para mas sharper daw yun turns...
    #51
    i can't seem to download the video.
    but i guess, the rack has to be centered first, before the alignment is performed.
    Mar 2007
    #52
    I still have my problem. Although lessened na. Changed all bushings and suspension related parts but still, nandyan pa rin. Ano kaya next ipatingin?
    Jan 2019
    #53
    Quote Originally Posted by box_type View Post
    Hindi sir, before rack change, okay yong right turn, means mas less na turn niya ngayon as before. Anyway checheck ko muna, sana may ibang cause, like may bracket or something labg na mali nailagay kaya may tumatama. If wala, check ko yong rack limiter na nasa video, baka meron nga nakalagay sakin. thanks sir.
    #54
    Quote Originally Posted by suysuy View Post
    Are you the first owner of the car?
    I was thinking baka may previous accident damage. Kapag hindi na pantay ang chassis ganyan ang usual symptoms kahit anung palit at adjust sa suspension ayaw talaga tumino.
    Mar 2007
    #55
    Yup first owner. Never been into an accident. Naging ganito na siya nung nagpalit ako ng lower arm bushings left and right. Hmmmm
    #56
    is it possible that, when they replaced the bushings, they failed to center the rack before aligning the wheels?
    #57
    OEM bushings? Replacing the whole arm might be the trick.
    rack doesn't need centering. its pre aligned for the steeeing shaft.
    Mar 2007
    #59
    Genuine kia bushings. The whole arm costs an arm and leg. Baka ndi maayos sayang lang pera. There might be something that is causing this. Disc brakes and calipers were already checked. So hindi siya issue sa brakes.
    There is something loose when you apply the brakes, it changes the steering angle or the suspension shifts. But im already running out of ideas kung alin sa ilalim ang need pang tingnan
    Mukhang may mali sa pagkabit ng rack and pinion mo. Hindi nga centered yan kaya bitin sa kabilang side ang turn.
    Sent from my SM-G965F using Tapatalk
Steering wheel alignment issue
