Results 1 to 20 of 93
    Jan 2019
    bro watch the video.. there is a rack limiter. baka magkaiba yun nakalagay..
    Thanks sir. May video pala. di ko Nakita nung una.
    brand new pa naman yong rack and pinion na binili ko, although Taiwan.
    wala na kaya ibang cause sir? problema kasi mas maraming turn steering wheel sa kaliwa kesa sa kanan.
    Jan 2019
    Quote Originally Posted by Ronpascual View Post
    Tsaka sir, napansin ko magkaiba yong haba ng nakalabas na tie rod thread sa left and right part. Possible bang cause ito?
    Feb 2005
    if you notice in the video magkaiba talaga turning degrees ng right and left wheels, so I guess hanggang dun na lang talaga turning point ng wheels mo? watch mo raw yung next video nya gagawa sya ng custom kits para mas sharper daw yun turns...
    i can't seem to download the video.
    but i guess, the rack has to be centered first, before the alignment is performed.
    rack doesn't need centering. its pre aligned for the steeeing shaft.
    so, when the brand new rack is purchased, it is already pre-aligned and "locked to the center position" ?
    thus, the mekanikos have to work the installation and alignment, without moving that setting?
    May 2011
    The SRS or airbag clockspring might not have been centered when the rack and pinion was replaced limiting the number of turns in one direction
    yes sir, steering rack is mounted on the subframe(crossmember) without any adjustment. the only adjustment is the tie rods but this doesnt affect the steering angle/limit if done right.
    Jan 2019
    Quote Originally Posted by box_type View Post
    Hindi sir, before rack change, okay yong right turn, means mas less na turn niya ngayon as before. Anyway checheck ko muna, sana may ibang cause, like may bracket or something labg na mali nailagay kaya may tumatama. If wala, check ko yong rack limiter na nasa video, baka meron nga nakalagay sakin. thanks sir.
Steering wheel alignment issue
