Page 20 of 42 FirstFirst ... 1016171819202122232430 ... LastLast
Results 191 to 200 of 420
    #191
    Quote Originally Posted by s_quilicot View Post
    pero whats the nitrogen machine is for? `00A% nitrogen?
    Extractor... To get the nitrogen to as high as 95%.
    #192
    to produce pure nitrogen gas for tire inflation.
    click the link: Benfits of nitrogen in tires
    http://letmegooglethatforyou.com/?q=...tires+benefits
    :google::google::google:
    #193
    Quote Originally Posted by yumyum View Post
    saan pede magpalagay and anong benefits makukuha ko?
    Select tire shops lang.
    As to benefits? It would greatly perceivable if you are a frequent hi-miler hi-speed highway traveler as it will heat and expand less contributing to a more stable tire pressure.
    BTW, there is a long discussion on nitrogen for tire here in the forum. Use the SEARCH function.
    Aug 2007
    #194
    If you mix air with pure nitrogen, you lose the benefits of having pure nitrogen in your tires. So whats the point of paying for pure nitrogen in your tires if you will just mix it with air?
    Exactly, we are in the realm of diminishing returns here. I believe having proper tire pressure would have more effect.
    Aug 2007
    #195
    Quote Originally Posted by Gerbo View Post
    Using bone dry air (compressed at high pressures) would have the same effect for me. Its not the O2, its the Moisture in Air.
    Here in the Middle East where people drive 120kph minimum for hours on end at ambient temperatures of 45 degrees, nobody uses them. And come to think, N2 here is cheap, since power is cheap.
    Dec 2007
    #196
    mga sir's anyone here tried using the nitro air in your tires? what is the advantage and disadvantage?
    May 2005
    #197
    one word: search. (existing thread on this subject)
    #198
    dont know the disadvantage yet.
    but for me i think the advantage
    of nitro air is hindi madaling lumambot
    1st week of march ako nagstart using
    nitro since nagchange kse ako ng magwheels
    and just last week lang ako nagparefill sa
    servitek 35.00 each but 2 front wheels lang
    nirefill kse the other 2 is still ok pa naman daw.
    #199
    Unless you are on long drives quite frequently, no perceptible difference from ambient air.
    And yes. Use the Search button. There's a long thread with an extensive discussion on this.
    #200
    unless you're running the track walang kwenta yan...but maraming mga racecar wannabe sa ibang forums that swears by it...
    dami daming PUV na ordinary air lang ginagamit wala naman nangyayari...whole day pa nasa road...
Nitrogen for Tires [Merged]
