Page 16 of 42 FirstFirst ... 612131415161718192026 ... LastLast
Results 151 to 160 of 420
    #151
    Quote Originally Posted by jundogg View Post
    hindi ba naflaflat ang gulong kapag naka nitrogen air?
    if theres a hole in your tire of course it will go flat.. no matter what you use.. i was stating that i used 80% nitrogen on my tires and i didnt suffer a blowout or flats... what i was trying to say was that i just use normal air.. which as we all know, 80% of oxygen is nitrogen...
    #152
    there's a tire shop along Evangelista st., Bangkal, Makati.... I just can't remember which is the nearest corner but if you're coming from EDSA southbound, turn right at Evangelista, just go straight about 3 or 4 corners from EDSA and keep your eyes peeled for a big sign with the word "Nitrogen"...
    I have a question, though...how do we know it's really nitrogen that they're putting into the tires?
    Apr 2006
    #153
    ah same lang pala. i thought may special power feature ang nitrogen air. hehe
    afaik, in normal condition, mababawasan lang naman ng hangin ang tires ng tsikot mo kapag hindi mo madalas gamitin ang ride mo. else, baka may singaw ang pito ng gulong kaya nagbabawas ng air.
    hintayin ko muna magmura eto before ill try. di kaya ng budget, pampagas ko nalang yun 100 per tire.
    Feb 2007
    #154
    sa sonny's ok banawe merun din. beside dencios.
    Aug 2004
    #155
    Tanong lang mga gurus. How do you make sure na nasa tamang PSI pa din ang nitrogen filled tires? Di ba may lumalabas na hangin sa gulong pag nagtsek ka using a gauge etc? Sayang naman yung refill.
    Aug 2007
    #156
    Quote Originally Posted by hyperthread View Post
    for me, when i thought my nitrogen-inflated tires have less nitro already after 2 months, i checked the PSI (early morning before driving para cold pa mga tires)--all had the same 32psi (supposedly 30psi lang lahat..when i had it inflated). so, i had to deflate a bit of the nitro from the tires to bring it to 30. medyo, sumobra pag deflate..umabot ng 28. . .that's when i had the tires refilled at minerva tire gallery (macapagal ave.) at only P50.00 for the 4 tires!
    medyo nag-alangan lang ako sa karga ng tires kaya i had the pressure checked...that was about 2 months or so before i had the tires re-filled. kung hindi ko siguro pinakaalaman, baka umabot pa ng 3 months bago ako nag re-fill...
    #157
    P50.00 for all 4 tires na? Sobrang mura ata. Honga mga peeps, how will we know if it is really Nitro that they are charging?
    Tsaka if I accidentally put in more air inside pero hindi Nitro but plain oxygen, what will happen?
    #158
    Usually mura kung may karga na na nitro sa tires. Kung pressure correcting lang. Pero kung idedeflate totally ang tires, mahal.
    Jul 2006
    #159
    70% of air is nitrogen. Go figure
  10. FrankDrebin Guest
    #160
    Halos lahat ng nakikita kong nitrogen machine ay mali pa ang spelling.
    "NITORGEN AIR"
    Mukhang pinagandang air compressor lang yata yun at Made in China pa lahat.
Nitrogen for Tires [Merged]
