Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Guys,
    How does changing to a bigger tire translate to power and speed?
    thanks,
    city
    It doesn't.
    Bigger tire = more unsprung weight
    Bigger tire = more revolution per turn for the crank/axle
    Bigger tire = more contact patch resulting to more resistance in initial roll.
    All points to No, it doesn't.
    What it does is increase the contact patch of the tire to the road resulting to better grip and handling.
    Dec 2003
    perfect answer!
    May 2005
    does that mean slower acceleration and speeds too?? Read also that wider tires means less grip on wet roads? thanks for any info.
    having bigger tires (i.e. as in wider) is likened to having a bigger footprint thus more friction against the road which means better grip. this translates to better control but the trade off is usually worse mileage as the engine has to work more in order to off-set the increased friction between the tire & the road. on the other hand, having bigger tires (i.e. as in thicker) is likened to having more cushion between the cars body & the road translating to a more supple ride, granting a normal tire psi. the trade off however, is also like having a wider tire.
    Bigger tires (in diameter) can help your fuel economy a bit i heard.
  7. #7
    so no gain on antyhing ha, except grip/handling...and looks pro'ly..thanks guys..thanks theveed!
    city
    Quote Originally Posted by city
    I think for powerful cars it can help in acceleration(less wheel spin) and braking because of the larger footprint/contact patch.
    For weaker cars, it can just make the car less aerodynamic, slightly slower and probably slightly less fuel efficient.
    Well, for more powerful cars, their wide tires are pretty much "stock" for them, kung baga, minimum requirement to get the power transferred as opposed to aftermarket upgrades wherein the stock 195 to 215 tires are more than sufficient.
    you won't benefit in terms of speed and power though handling may improve.
    but certainly pogi points would benefit...
May gain ba pag nag palit mas malaki at malapad na tires?
