Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 159
    Jun 2010
    With my 2016 FXT running 37k kilometer
    1. No oil consumption on my FA20DIT and I use 5w30 FS oil. I think the oil consumption issue is related with the EJ25 engine.
    2. None
    3. None
    4. No issues so far with the aircon and I hope it stays that way.
    5. Changed my front lower arm bushings at 32k kilometers. Spent around 4k for the 4 bushings plus labor.
    6. FC on heavy traffic areas like BGC is around 5 km/L, medium city traffic would be around 7 km/L, spirited highway driving gets me 10 km/L, highway driving doing only 80-90 kmh can do 12 km/L.
    Where did you buy the suspension parts for your SJ sir? Ang mahal kase ng quote sakin ng Subaru Greenhills for replacement of bushings + stab link + labor.
    Quote Originally Posted by dinJ View Post
    Go to HMS Auto Saloon in Banawe. They offer original and replacement bushings. Replacement ones are just 500 each and most say they last as long as original ones. By the way, Subaru uses the same bushing for the SG, SH, and SJ Foresters.
    I had the bushings installed at Velocity Underchassis in Mandaluyong for less than 2k and that includes machine pressing of the bushings.
    Jun 2016
    So far eto naresearch ko:
    1. High oil consumption, as much as 5 liters oil per 1500 km. That is like having an oil change every 2 months of normal use.
    2. Oil leaks from the oil pan and head cover.
    3. Cylinder head gasket problem. Can be very expensive.
    4. Aircon problems. Kaya pala madami naka advertised na forester aircon condensers and evaporators.
    5. Bushings and other suspension and steering parts.
    6. And bad fuel economy.
    Looking elsewhere.
    I have a forester xt. Bought it in late 2019. 25k in the odo. Wife uses it. City driving. Paved roads almost entire time except for a few usual bumps here and there. Surprised i had to change bushings and rack end.
    That soon?
    Quote Originally Posted by exon View Post
    That soon?
    Yes, their bushings are not that good. I had to change mine twice before it reached 40k kms. Then, I switched to aftermarket bushings. Ran it for 35k kms so far. No problems so far.
    Sent from my SM-T970 using Tsikot Forums mobile app
    Jun 2013
    That soon?
    bushings yes.
    rack end, no
    Jan 2018
    Re: fuel economy, it really depends on what car are you comparing it to?
    My Subbies are around 4-5 km/ltr City and 10-14 km/ltr Highway.
    Foreign consumer reports ang sources ko, for the 2009-2012 models.
    Medyo nakakatakot yung cylinder head gasket problem. I saw 8 reviews reporting such. I've had a lemon car once*, e kung swertihin ako ulit. Lalo na i'll be buying 2nd hand.
    Yung sa aircon even local sellers seem to be aware (or have experienced?) Huli agad, either they say "newly replaced condenser..." or say "trouble free aircon...". Parang sinasabi na ok na wala na problem yung ac.
    *1-1/2. The everest was begining to exhibit weird signs that is why i decided to prematurely dispose of it. Usually 5-6 years bago ako magpalit ng kotse. 3 years lang yung eve sa akin. Napaso na takot na.
    Uh-Oh.....Recall seems to be destroying FA20s[emoji848]
    Scion FR-S, Subaru BRZ Owners Claim a Recall Fix Is Destroying Their Engines - The Drive
    2008 impreza 2.0 rs here.
    80k kms already.
    2. No oil leaks
    3. Cylinder head gasket problem.<~ replaced once, both sides. Mura part, mahal labor.
    4. Aircon problems. 2x evaporator, 1x thermistor
    5. Bushings and other suspension and steering parts. <~ seems like every 40k kms, i have to replace these...
    Replaced power steering pump once at 20k kms, casa wants to replace my 2nd pump again at 60k kms, i didn't follow that. Still at my 2nd pump. (noisy at cold engine, normal when warmed up)
    All shocks replaced at 70k kms
    4 Wheel bearing replaced at 70k kms
    Transmission fork replaced at 75k kms... How the heck does that break? My 1998 sentra still has those orig forks.
    6. And bad fuel economy. <~ awd, 2.0 is a bad combo in traffic
    But despite all the things that broke. Still love to drive that thing.
    Feb 2009
    Sir istan, question po:
    Quote Originally Posted by istan View Post
    80k kms already.
    At what odometer reading (or vehicle age) did the head gasket and evaporator leak?
    If i remember correctly, gasket replaced at 65k kms
    Evap at 50k kms, 2nd time at 87k kms.
    Travel around 10k a year.
    2nd time evap, replaced together with thermistor. May small leak na raw according to coolmate.
    Coolmate for my aircon needs, casa for gasket and power steering pumps
    Feb 2009
    Thanks for the info, Sir istan!
    Mar 2004
    Mazda and Subaru quality is nowhere near that of Honda and Toyota ... Fanbois are just in denial ...
    mazda6 and the xv are rated reliable by consumer reports.
    sure the older models are not as reliable but newer models tend to improve. example.. really old honda jazz... its improved over the years.
    I wouldn’t buy an overpriced CUV for just its brand name. Given a choice between a Forester or CX5 over a RAV4 for the price they have now, it’s a no brainer unless I’m a Toyota fanboi.
    Or maybe an Altis 2.0V over a Mazda3 2.0R, there is no question.
    '07 WRX
    Big turbo, exhaust, tune
    68k kms
    replaced power steering pump at 40k
    major work at 50k kms/10 years old:
    replaced radiator (started leaking at the plastic end tanks), did thermostat and water pump at the same time to be safe
    also did ball joints and tie rod ends
    replaced shocks and top-mounts (fitted coil-overs) at 65k kms
    recharged a/c at 68k kms. o-rings needed replacement, but everything else (evaporator, etc) was intact.
    planning on doing timing belt and tensioner at 70k. already have the parts.
    Aug 2004
    2018 XV. Replaced the evaporator 2021. Replaced the low-side hose and expansion valve just this afternoon. Kinabahan ako akala ko compressor na because it was making an unusual noise. Yun pala it was a symptom of low freon pressure already.
    Have u test drove all 4?
    Mar 2004
    Will test driving vehicles tell one how reliable they are? ...
    Test driven ...
Common Subaru problems
