Page 8 of 16 FirstFirst ... 456789101112 ... LastLast
Results 71 to 80 of 159
    #71
    Quote Originally Posted by dartz View Post
    Hi guys, im eyeing to buy a second hand Subaru Impreza Hatch as to my spirited and car show type car. my budget as of now is 500k-600k saw some looks good units on OLX. Any checklist to look out for when checking out the car and any specific year or variant I should look into na much better compare to other units. I'm eyeing for 2013 onwards model if ever.
    See my post, 1st page.
    I noticed lately that the thermostat on the forester iP switches on and off frequently. I did not use Auto-temp and the fan is on 2. Is this normal or a symptom of a bigger problem?
    Mr. BIG?
    #73
    Mr. BIG?
    Bro, ilang months na ba yung Fozzie mo? Did you observe any other issues? Di kaya kelangan na ng new battery?
    1 year and 3 months na bro. So far un lang napansin ko na unusual. You can feel the shudder kasi pag on ng thermostat.
    Apr 2008
    #75
    Try to get the temperature sensor inside the cabin to be checked (bottom of the dash beside the steering wheel if I remember correctly). Baka madumi lang at nahaharangan kaya hindi accurate ang readings niya. Na-try mo na bang i-todo ang thermostat to the coldest to see if the frequent on/off still happens? O kaya itodo sa pinakamainit na setting para hindi siya mago-on dapat at all?
    Jul 2017
    #76
    Good pm ask ko lang po kung worth buying pa "well maintained" subaru legacy wagon 1996? At 179,000 km. Thanks!
    Aug 2017
    #77
    Well my experiance, quite simply was, turbo charger, turbo charger, TURBO CHARGER! You gotta look out for that one.
    #78
    Quote Originally Posted by juliancohen View Post
    As with any car with a turbocharger, either gas or diesel, utmost care and maintenance is needed or else it going to cost you a lot to fix it.
    Dec 2009
    #79
    Hi,
    Just wish to ask if it's normal to hear a howl noise when running around 15kph below? I'm not sure if this was present before. Vehicle is 2017 Forester 2.0iL and only has 600+km in the odo. TIA.
    Quote Originally Posted by jvo View Post
    Hi,
    No, it is not normal. Have you checked if all windows are closed?
Common Subaru problems
