Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 159
    Sounds like a wrong cvt fluid was used.
    Feb 2009
    Plan ahead and put money aside for timing belt and associated parts replacement! These engines are interference type. If the belt breaks or slips, severe engine damage are more than likely.
    May 2011
    All vehicle maintenance/repairs done at Subaru BGC ever since it was bought.
    Jul 2015
    defective parts caused by AOG..
    Aug 2004
    How many kilometers?
    How often have you replaced the transmission fluid? Should do it every 20-40k kilometers, AFAIK, to ensure the transmission stays healthy.
    Apr 2012
    usually transmission fluid is replaced after 100k km of use. this is the reason im hesitant to own a cvt/at car. im afraid cvts will not last longer than mt. my xv has 40k kms in the odometer and still in perfect condition.
    Quote Originally Posted by Jakespeed800 View Post
    Yan ang mali sa karamihan. Guessing and generalizing 100k? Why not read owners manual... naka sulat naman
    Apr 2012
    If im not mistaken, it is 120k kms.
    Aug 2009
    Do you still go to the casa for maintenance? Almost all XV owners i know had their CVTs flushed at 40k..
    I noticed lately that the thermostat on the forester iP switches on and off frequently. I did not use Auto-temp and the fan is on 2. Is this normal or a symptom of a bigger problem?
    Mr. BIG?
    Mr. BIG?
    Bro, ilang months na ba yung Fozzie mo? Did you observe any other issues? Di kaya kelangan na ng new battery?
    1 year and 3 months na bro. So far un lang napansin ko na unusual. You can feel the shudder kasi pag on ng thermostat.
    Apr 2008
    Try to get the temperature sensor inside the cabin to be checked (bottom of the dash beside the steering wheel if I remember correctly). Baka madumi lang at nahaharangan kaya hindi accurate ang readings niya. Na-try mo na bang i-todo ang thermostat to the coldest to see if the frequent on/off still happens? O kaya itodo sa pinakamainit na setting para hindi siya mago-on dapat at all?
    Aug 2017
    Well my experiance, quite simply was, turbo charger, turbo charger, TURBO CHARGER! You gotta look out for that one.
    Quote Originally Posted by juliancohen View Post
    As with any car with a turbocharger, either gas or diesel, utmost care and maintenance is needed or else it going to cost you a lot to fix it.
    Dec 2009
    Hi,
    Just wish to ask if it's normal to hear a howl noise when running around 15kph below? I'm not sure if this was present before. Vehicle is 2017 Forester 2.0iL and only has 600+km in the odo. TIA.
    Quote Originally Posted by jvo View Post
    Hi,
    No, it is not normal. Have you checked if all windows are closed?
    Dec 2009
    Yup, all windows are closed. I can still hear it even when front windows are open. What could be the possible cause. It's to early if it is because of wheel bearing. And can't hear the noise at higher speed. Not sure if its the tires?
    Jan 2018
    Im considering a 2010 WRX hatch. Anything I should look out for?
    Jan 2018
    Quote Originally Posted by 4A92 View Post
    Check for leaks from the engine and shocks. The oil seals would have worn out by this time if they have not yet been replaced.
    Check for boost leaks and for any knocking or pinging during hard acceleration.
    Check that the aircon is still blowing cold air. Also check the condition of the cabin filter. Ask if the evaporator has ever been replaced.
    Ask to see the maintenance stamp book if it was serviced in the casa.
    Check the level and quality of all fluids: oil, coolant, brakes, power steering, transmission. Ask when these were last drained and replaced. Not just topped off.
Common Subaru problems
