Page 8 of 8 FirstFirst ... 45678
Results 141 to 159 of 159
    #141
    Mazda and Subaru quality is nowhere near that of Honda and Toyota ... Fanbois are just in denial ...
    Have u test drove all 4?
    Mar 2004
    #142
    Will test driving vehicles tell one how reliable they are? ...
    Test driven ...
    #143
    Test driven ...
    One will know best w/ longterm ownership.[emoji4]
    Feb 2019
    #144
    Any wrx 2014 and above cvt owners here? Any known issues?
    #145
    Quote Originally Posted by Adrianf13 View Post
    If properly maintained, there would be no issues. The WRX and XT uses the same engine and tranny with differences in tuning only.
    If the car is regularly used, the previous owner may have changed the CVT fluid, front suspension bushings, brake pads, and tires. Unless of course, the car was sparingly used (garage queen). Check the tires for the manufacture date. You need to change tires if they are more than 5 years old already.
    Feb 2019
    #146
    New thick tires. Has 24k mileage only. Just heard people saying about cvt transmission issues same with xt.
    #147
    CVTF change interval is every 40k km actual mileage. I bet the owner has not changed CVT fluid or brake pads.
    Jun 2016
    #148
    So far eto naresearch ko:
    1. High oil consumption, as much as 5 liters oil per 1500 km. That is like having an oil change every 2 months of normal use.
    2. Oil leaks from the oil pan and head cover.
    3. Cylinder head gasket problem. Can be very expensive.
    4. Aircon problems. Kaya pala madami naka advertised na forester aircon condensers and evaporators.
    5. Bushings and other suspension and steering parts.
    6. And bad fuel economy.
    Looking elsewhere.
    I have a forester xt. Bought it in late 2019. 25k in the odo. Wife uses it. City driving. Paved roads almost entire time except for a few usual bumps here and there. Surprised i had to change bushings and rack end.
    That soon?
    #149
    Quote Originally Posted by exon View Post
    That soon?
    Yes, their bushings are not that good. I had to change mine twice before it reached 40k kms. Then, I switched to aftermarket bushings. Ran it for 35k kms so far. No problems so far.
    Sent from my SM-T970 using Tsikot Forums mobile app
    #150
    '07 WRX
    Big turbo, exhaust, tune
    68k kms
    replaced power steering pump at 40k
    major work at 50k kms/10 years old:
    replaced radiator (started leaking at the plastic end tanks), did thermostat and water pump at the same time to be safe
    also did ball joints and tie rod ends
    replaced shocks and top-mounts (fitted coil-overs) at 65k kms
    recharged a/c at 68k kms. o-rings needed replacement, but everything else (evaporator, etc) was intact.
    planning on doing timing belt and tensioner at 70k. already have the parts.
    Jun 2013
    #151
    That soon?
    bushings yes.
    rack end, no
    Aug 2004
    #152
    2018 XV. Replaced the evaporator 2021. Replaced the low-side hose and expansion valve just this afternoon. Kinabahan ako akala ko compressor na because it was making an unusual noise. Yun pala it was a symptom of low freon pressure already.
    #153
    yespo.
    some compressor systems shut down, when freon pressure goes low for whatever reason.
    Aug 2018
    #154
    I only had to replace once the bushings on my 2016 Subaru FXT. My a/c also started to fail. So, I went to see Fusion R's resident a/c guy and he said it is still usable so he just charged additional freon to keep my a/c working. But my ever dependable talyer, however, took out the evaporator and cleaned it. He placed it back and the a/c still works well for more than 5000 km now. He sure did save me from inccuring additional expenses.
    #155
    Quote Originally Posted by fudtripers View Post
    so what was wrong with your aircon, causing it to fail?
    Aug 2018
    #156
    The talyer guy showed me the evaporator was contaminated with oil already.
    #157
    ah!
    good for you, sir!
    Aug 2018
    #158
    I dunno if this is a common problem but, at 35k km, the Fusion R mechanic suggested that I go to a shop in Banawe specializing in fixing up my FXT's EPS. He said that if mine fails (malakas na daw yung play niya), MI will charge more than 100k to replace it while this shop in Banawe fixes it for 10k only. Sure enough, I followed the mechanic's advice and had the shop in Banawe fixed my eps in a little over 3 hours. My odo is at 40k km now and when I asked a different Fusion R mechanic to check my eps, he said it's still good. Thank God!
    Aug 2004
    #159
    There is a bit of play (and thunk) in the steering especially when doing a tight turn and you hit a bump. My XV came with it. My friend also observed it on his WRX. Possible cause is the coupling that allows the steering to collapse on impact.
Common Subaru problems
