Results 141 to 150 of 2730
August 29th, 2006 02:51 PM #141
Hello, welcome to the boards. There are other MB100 threads here. Use search and the keyword 'mb100' (no space) and you'll get about 10 threads.
Have a '97 since new. No problems with it. Pioneer HU, basic AV set up. Had all the recall items fixed by CATS (door handles, air intake, A/C plumbing).
Basically stock and running on Goodyear Wrangler tires.
November 6th, 2006 05:16 PM #142
pwede bang palitan ang mags ng mb? parang wla akomg nakikitang nag papalit nito.
November 6th, 2006 06:42 PM #143
Pwede ata pero mahirap maghanap ng same PCD (alam ko pareho sila ng PCD ng Mercedes Benz G-Wagen). Yung last units ng MB100 naka rims with hubcaps na lang.
November 6th, 2006 07:00 PM #144
doc otep good day, naka bli na pla ko mb100 kaya lang mga monday pa makukuha pinapagawa pa yung aircon. 44 thou lang ang odo, kaya lang nabasa ko thread dto na dodoktor pla odo. anyway any suggestion kung ano dapat palitan o ipa check besides change oil? since 44 thou na sya. tenks
- Nov 2003
- 92
November 6th, 2006 08:56 PM #145
November 6th, 2006 09:54 PM #146
Change mo fanbelt kasi nga isa lang. Check the suspension and brakes. Yung handbrake minsan ayaw kumagat.
Change the oil, oil filter, air filter, and fuel filter. You can also have the coolant flushed and refilled with 50/50 coolant mix. The maintenance schedule of the MB100 is on the decal under the hood [mababali leeg mo trying to read it]. Even with mineral oil, every 10,000 kms lang ang oil change niya.
If yours doesn't have the decal, you can PM me, I'll try to take photo of it. Or at least copy the contents.
November 7th, 2006 09:39 AM #147
ah, ok. tenks for the reply ill post again once a get the unit. do you have any idea how much is the belt? kapareho pla sya ng starex.
November 7th, 2006 11:20 AM #148
[quote=asag;687302]. clutch the pedal and the kambyo.
[/hquote]
what about this clutch the pedal and the kambyo? what are the problems regarding these parts? should i chage the clutch pedal and kambyo to a new one since its already 44thou? pls enlighten. thanks asag!
November 7th, 2006 01:13 PM #149
Replace the clutch only when it is showing signs of being worn already.
I've no problems with the clutch pedal, it's the clutch cable that snapped a few years ago (the new one installed has not failed since).
The revised shifter is a pretty big part. I can't recall the price. You'll know it's the revised shifter because the shift knob is no longer quick release (you screw it on like in most other cars). A quick release shift knob was initially used because you needed to take out the shift knob in order to open up the 'doghouse' engine cover in the cabin.
November 23rd, 2006 11:20 AM #150
i got my mb last week tuesday, i did not post rayt away because i want to test it first. wow! we"ve been to subic this tuesday and went back just yesterday evening, i say wow again because the mb is so comfortable! compared to other van that i rode. rough roads? never mind its just like riding a tourist bus! the handling perfect! i can say now that im one of you guys who is very very satisfied with our MB100 Van. tenks for all the imputs it really help a lot! :cool: btw im the driver.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
