Results 171 to 180 of 2730
December 20th, 2006 08:21 PM #171
Wala pa naman akong piyesang hindi nahanap. :D hehehe. Hindi pa nga kami nag-rerecalibrate or any major engine work. Puro maintenance lang. Mas mausok pa Pajero ko.
December 20th, 2006 08:40 PM #172
yup ok pa nman,check na rin if mausok and kung may kakaiba na tunog sa engine, hindi nman mahirap maghanap ng parts for body and engine sa banawe lang sir marami na makikita...
December 30th, 2006 11:33 AM #173
patulong lang hindi ko matanggal yung headlight ng mb, kasi yung manual ko korean di ko maintindihan. kakabit ko kasi yung hose ng windshield washer sa motor nya nahugot di yata pwedeng dukotin ng hindi tinatanggal yung headlight. dalawang turnilyo lang nakalabas tapos yung isa sa signal light tanggal ko na yung tatlo ayaw parin matanggal nung head light. salamat.
January 3rd, 2007 01:08 AM #174
Kakapalit ko lang ng foglamp bulb.
To remove the headlamp:
Remove two nuts in the middle/inner side of the headlamp
Remove turn signals. One screw is on top of headlamp near the outer edge. The other below the front part of the signal lamp.
TAKE OUT THE SIGNAL LAMP (Careful, you might break the clips)
You will expose two 10mm nuts that hold the headlamp. Take these off.
Pull headlamp wiring harness off (it is on the outer edge of the headlamp accessible from above).
Pull headlamp away from vehicle.
Installation is reverse of removal.
January 8th, 2007 09:21 AM #175
thanks doc! i have already attached the hose to the washer and perfectly working now. i have another slight problem, the sliding windows of my mb are very hard to open! what lubricant can i use to make it more easy to slide? im worried that it might get stock.
thanks again and Happy New Year!!!
January 8th, 2007 01:12 PM #176
Hmmm...never bothered to lubricate the windows since I don't like the passengers opening them. Probably makes it more difficult for thieves, too.
You can try mineral oil. They sell it at your local drugstore.
January 8th, 2007 10:10 PM #177
hello to all! its my first time hehehe! ingit kc ako s mga conversation nyo................ hope you could help me coz im planning to buy my first car this summer
January 9th, 2007 11:51 AM #178
January 9th, 2007 11:56 AM #179
Satisfied pa din kami. Drove it December 27 to Pampanga, medyo overloaded pa dahil 13 kaming sakay and with luggage pero comfy pa din sa loob. Natraffic ako pagluwas ng Manila dahil sa illegal parking sa Balintawak market pero ok din lang. Magaan naman dalhin MB100.
Best buy would be the unit in the best condition, I guess. Since they are all used cars. I prefer local units even if the imports have more features.
January 9th, 2007 12:34 PM #180
If you find one that had been properly maintained by the owner, and driven by the owner himself then it should be a good buy.
My Tito had one which i used from time to time; it was basically stock except for the Alpine CD changer, stepboard, roof rail and upgraded headlight wirings/bulbs. It also had it's share of problems but was generally reliable and was used out of town a lot... repairs and rust started mounting after the 3rd year (it was driver driven though)... they sold it after using it for around 6 years w/ 100,000kms on the odo.
VinFast VF 3
