Page 15 of 273 FirstFirst ... 51112131415161718192565115 ... LastLast
Results 141 to 150 of 2730
    #141
    Hello, welcome to the boards. There are other MB100 threads here. Use search and the keyword 'mb100' (no space) and you'll get about 10 threads.
    Have a '97 since new. No problems with it. Pioneer HU, basic AV set up. Had all the recall items fixed by CATS (door handles, air intake, A/C plumbing).
    Basically stock and running on Goodyear Wrangler tires.
    Sep 2006
    #142
    pwede bang palitan ang mags ng mb? parang wla akomg nakikitang nag papalit nito.
    #143
    Pwede ata pero mahirap maghanap ng same PCD (alam ko pareho sila ng PCD ng Mercedes Benz G-Wagen). Yung last units ng MB100 naka rims with hubcaps na lang.
    Sep 2006
    #144
    doc otep good day, naka bli na pla ko mb100 kaya lang mga monday pa makukuha pinapagawa pa yung aircon. 44 thou lang ang odo, kaya lang nabasa ko thread dto na dodoktor pla odo. anyway any suggestion kung ano dapat palitan o ipa check besides change oil? since 44 thou na sya. tenks
    Nov 2003
    #145
    Quote Originally Posted by SELEGNA_35 View Post
    the belt. mb 100 has only one. fuel filter. clutch the pedal and the kambyo.
    these are the ones that i have had problems with.
    #146
    Change mo fanbelt kasi nga isa lang. Check the suspension and brakes. Yung handbrake minsan ayaw kumagat.
    Change the oil, oil filter, air filter, and fuel filter. You can also have the coolant flushed and refilled with 50/50 coolant mix. The maintenance schedule of the MB100 is on the decal under the hood [mababali leeg mo trying to read it]. Even with mineral oil, every 10,000 kms lang ang oil change niya.
    If yours doesn't have the decal, you can PM me, I'll try to take photo of it. Or at least copy the contents.
    Sep 2006
    #147
    ah, ok. tenks for the reply ill post again once a get the unit. do you have any idea how much is the belt? kapareho pla sya ng starex.
    Sep 2006
    #148
    [quote=asag;687302]. clutch the pedal and the kambyo.
    [/hquote]
    what about this clutch the pedal and the kambyo? what are the problems regarding these parts? should i chage the clutch pedal and kambyo to a new one since its already 44thou? pls enlighten. thanks asag!
    #149
    Replace the clutch only when it is showing signs of being worn already.
    I've no problems with the clutch pedal, it's the clutch cable that snapped a few years ago (the new one installed has not failed since).
    The revised shifter is a pretty big part. I can't recall the price. You'll know it's the revised shifter because the shift knob is no longer quick release (you screw it on like in most other cars). A quick release shift knob was initially used because you needed to take out the shift knob in order to open up the 'doghouse' engine cover in the cabin.
    Sep 2006
    #150
    i got my mb last week tuesday, i did not post rayt away because i want to test it first. wow! we"ve been to subic this tuesday and went back just yesterday evening, i say wow again because the mb is so comfortable! compared to other van that i rode. rough roads? never mind its just like riding a tourist bus! the handling perfect! i can say now that im one of you guys who is very very satisfied with our MB100 Van. tenks for all the imputs it really help a lot! :cool: btw im the driver.
MB100, Ssangyong/Daewoo Istana [ARCHIVED]
