Results 2,221 to 2,230 of 2560
- Jul 2010
- 570
February 21st, 2015 10:56 PM #2221Meron ba naka sindi na check engine lamp sa gauge mo?
Pa check mo fuel pump pressure ng engine. Baka mahina bigay ng fuel. Dapat around 40 PSI ang fuel pressure.
- Mar 2014
- 901
February 22nd, 2015 12:39 AM #2222In short saying... Palyado.
Sa gas engine carb of efi type, you need too inspect and checked a lot to narrow down what is causing your engine to malfunctioned nor stall.
Since you mentioned MAF sensor and servo I assumed you got an EFI engine, if I'm not mistaken.
First. When did it happened that you encountered that symptoms in your vehicle? Is it wasn't like that before?
Sent from my Starmobile UP+ using Tapatalk.
- Aug 2014
- 14
February 23rd, 2015 11:28 AM #2223gud day mga bossing tanong ko lang, ano problema ng sasakyan pagkapinapatakbo ko na sya ng mabilis (60 kph above) may umuugong na masakit sa tenga pag mga 40 lang takbo wala nman. maraming salamat po.
and, mga bossing magkano po ang suspension? medyo may gumaganit kasi may bandang taas ng gulong ko sa harap lalo pag dumaan ako sa rough road..maraming salamat po mga idol.
February 23rd, 2015 05:35 PM #2224
baka naman may naglagay ng pito sa dulo ng tambutcho kaya habang bumibilis ang takbo ng kotse ay lalong umiingay gaya ba ng nasa PUV. dyok lang bro.. ikaw naman di ka mabiro. hehe
seriously, what do you mean umuugong? para bang nakakairitang ingay? na check mo na ba yung exhaust /muffler baka lang may maliit na butas na ito kaya mas maingay kapag ang speed ay 60kph & above
- Jul 2010
- 570
February 26th, 2015 09:50 AM #2225Pa check mo mga whel bearing . Release yun handbrake at angat gulong. Manually ikutin gulong at alugin. Check kung may magaspang na tunog na sign ng sirang bearing.
- Aug 2014
- 14
February 26th, 2015 10:12 AM #2226
- Nov 2014
- 9
March 7th, 2015 12:36 PM #2227Mga sir saan po maganda at murang magpagawa ng power steering may leak kasi. Atsaka po mga pang ilalim saan ok at mura magpagawa. Thanks
- Nov 2014
- 9
March 7th, 2015 12:37 PM #2228Mga sir saan po maganda at murang magpagawa ng power steering may leak kasi.
March 14th, 2015 09:26 AM #2229
good morning mga sirs!
ano po ba ang spec ng engine coolant ang ginagamit nyo? balak ko sanang top-up ng coolant, di ko lang alam kung anong brand nito. salamat po.
- Mar 2008
- 54,246
March 14th, 2015 10:30 AM #2230- - - - - - - - - - - - - - - - - - - - - -
i used to have a mits. but forget kuna ang brand ng coolant.
but i remember mitsu uses the red-colored coolant.
to be sure, you can purchase this from the casa.
take note of the dilution instructions.
on top-up, use red on red, and green on green, even if different brand.Last edited by dr. d; March 14th, 2015 at 10:33 AM.
Some other dcts, like dun sa mga 1.6 na hyundai & kia crdis, nagka-issue rin bt. Not sure lang if...
2022 Hyundai Creta
