Page 211 of 257 FirstFirst ... 111161201207208209210211212213214215221 ... LastLast
Results 2,101 to 2,110 of 2561
    #2101
    Have your battery checked. Kung ok pa check your alternator baka palitin na ang brushes.
    Your starter might need cleaning na din.
    #2102
    Hi mga co-itlogers,
    seeking for advise po.. mine is gli-96, nag-overheat sya last sunday, my naputol na hose, pag-stop ko, namatay engine, overheat n pala.. nagpa-compression test me ngyn, results are 150,180,180,90.. general overhaul daw as per mechanic.. estimate is 25-35k dpende kung my tama liner or ok p piston, i-back to normal/std daw, big money... are the results calls for general overhaul talaga at ganun tlaga kmahal ng gen. overhaul? pwede ko p kaya gamitin to or anytime pwede n sya tumirik? tnx in advance sa mga advisers..
    May 2012
    #2103
    Sir magpa second opinion ka.. and saan location mo para mabigyan ka ng recommended shop sa location mo
    Posted via Tsikot Mobile App
    #2104
    Quote Originally Posted by spikebreaker00 View Post
    Dito sir sa sta. rosa city, laguna.. any recommended shops? thanks
    May 2012
    #2105
    Pwede sa Cavite Crew MLPH sa Gen. Trias CAVITE recomemded yon
    #2106
    Quote Originally Posted by m8m8 View Post
    Hi mga co-itlogers,
    does the car still run smoothly? no smoke? will it pass emissions test?
    if yes, i suggest you just keep using it.
    just because the engine overheated, does not mean an overhaul is necessary.. for all you know, matagal nang ganyan ang compression values mo...
    Aug 2014
    #2107
    tama si dr. d. make sure lang na may sapat tubig ang radiator at silipin mo rin kung umiikot ang tubig sa loob nito. kung ako sayo, medyo babaan mo na lang ang rev mo bago mag shift. malay mo tumagal pa yan.
    Jul 2010
    #2108
    Hi mga co-itlogers,
    Dati nasira din 4G13 engine ko sa overheat. 35k din quotation sa akin. Ako na lang nag diy rebuild ng 4G13 engine ko. Total of 12k lang nagastos ko at nagkaroon pa ako ng mag tools.
    Isipin mo lang ang gastos sa machine ay 4k lang .
    Hanap ka uli ng iba mechanic at silipin mo rin yun liner kung may lubog na sa portion kung saan titigil ang piston ring at doon mag fire yun spark plug. Doon magkaroon ng lubog at singaw.
    Feb 2014
    #2109
    mga bossing pa help po.. bigla na lang di gumana aircon ng lancer el96 ko. pati fan di na gumgana ...check ko fuse box ok naman lahat ng fuse.
    #2110
    Quote Originally Posted by cmm0520 View Post
    how bout the relays?
