Results 2,001 to 2,010 of 2561
- Mar 2014
- 16
March 20th, 2014 03:42 PM #2001hello to all. Owner of Lancer Hotdog 93-96 model.
GLi pawis steering.
New member here at Tsikot forums.
- Mar 2014
- 3
March 20th, 2014 06:38 PM #2002mga sir, baka may kakilala po kayo na mekaniko near sta. rosa, may problem po kasi ako sa lancer ko 93 glxi taas baba ang menor nya. pag unang start nasa 2k ang rpm then after that tass baba na from 1.5k-2k.
March 20th, 2014 06:58 PM #2003
- Mar 2014
- 16
March 21st, 2014 09:55 AM #2004Sirs.. mga how much damage to convert my hotdog GLi to power steering? Is this still advisable?
March 21st, 2014 10:19 AM #2005
Our EL was converted to power steering. Cost almost 20k total. You can get it for less but I won't cheap out on a conversion like this. If you plan to keep the car for a long time and it's your daily driver then sulit sya.
- Mar 2014
- 16
March 21st, 2014 03:50 PM #2006May kamahalan din pala ano sir. Actually sa akin wala problema. Ang nahihirapan talaga is si wifey. San ba may shop at Bacoor (or nearby) na trusted na ng Tsikot members? Thanks!
- Mar 2014
- 3
- Mar 2014
- 3
March 21st, 2014 11:19 PM #2008mga sir, pwede ko po ba i-convert from manual to matic ung tranny ko "lancer 93", how much po kaya aabutin? tnx....
- Mar 2014
- 16
March 23rd, 2014 12:27 PM #2009
March 24th, 2014 11:17 AM #2010
Medyo madugo. You need a TCU (transmission control unit), shifter (na baliktad ang orientation most likely dahil JDM), gauges (para may gear indicators)and radiator (AT radiators have ATF coolers built in). And trannies of that age are already old and will need lots of TLC. You might be better off getting a front cut that has an AT engine and moving everything to your car. However at the price of a conversion mag-down ka na lang on a cheap AT small car. Mas reliable pa in the long run.
i would expect something like this, if the authorizing authority did not have a clear idea of their...
Suzuki Fronx
