Results 1,391 to 1,400 of 2560
- Jul 2011
- 23
August 22nd, 2011 12:42 PM #1392
- Aug 2011
- 9
- Apr 2011
- 11
August 26th, 2011 01:12 PM #1394sa Idling mo po sir better to clean your Throttle Body at yung MAP Sensor yung dinadaluyan ng Air patungo sa Throttle Body mo malamang sobrang dumi na nya.
kung ganon pa rin IDLE mo at Bumabagsak pa rin RPM mo,.check the voltage ng TPS mo baka wala na sa 1 volts pag nagawa nyo po yan sir paki Inform po ako kung naging OK po ba?
- Sep 2011
- 2
September 6th, 2011 11:23 PM #1395mga sir, anu-ano ba mga chini-check
kapag magpapa-tune up?
how much ang kailangan budget para dito?
dalhin ko kasi sa probinsya ang sasakyan
kaya gusto ko nasa magandang
kondisyon ang sasakyan para
hindi masiraan sa gitna ng byahe. ^_^
- Sep 2011
- 5
September 8th, 2011 08:05 AM #1396hello po mga sir..
newbie here po..my question po aq bumili aq ng lancer itlog 93 glxi model pag ng on ako ng key meron buzzing sound sa my makina tpos naka light ung check engine after 1 min nawawala ung tunog nawawala din ung light ng check engine.. nabili q ung lancer q naka bypass na ung servo naka actuator na cya eh... thank need your help tlga
September 8th, 2011 12:06 PM #1397
*Gian12,
normal lang naman paps pag umilaw check engine upon ignition, AFAIK siya yung last na ilaw sa gauge na mawawala.
wait till the check engine light goes off before switching on the engine, ibig sabihin nun tapos na mag-boot ang computer box and your car is ready to go.
- Sep 2011
- 5
September 8th, 2011 01:47 PM #1399
normal din yun, umiikot na kasi yung servo mechanism sa loob ng throttle body kapag naka-on na sa susi.
ganyan din sa glxi namin.
- Sep 2011
- 5
September 8th, 2011 02:04 PM #1400*zero
Sir question po pag ganun d ayus pa po cervo ko naka bypass na kc ung servo ko pag mg a/c gusto q ibalik sa servo ulit
Senators suggest window hours in odd-even system on Edsa rehab Senators urge window hours in...
SC (temporarily) stops NCAP
