Results 241 to 250 of 420
July 15th, 2009 06:18 PM #241
BANNED BANNED BANNED
- Nov 2008
- 1,383
July 16th, 2009 01:37 AM #242
August 8th, 2009 05:51 PM #243
ganda ba pag hydrogen ang gagamitin para sa tire? ano ba ang difference sa hydrogen at saka sa ordinary na air?
August 8th, 2009 05:54 PM #245
Hydrogen is a highly flammable gas. It's not recommended. Baka matulad sa Hindenburg yung goma mo, hehehe.
I think you mean nitrogen. Since its an inert gas, hindi siya masyado affected by temperature, so constant yung pressure niya inside the tire.
August 8th, 2009 06:43 PM #246
"ordinary" air consists of 78% Nitrogen. Hydrogen will just seep through.
- May 2009
- 93
August 9th, 2009 02:06 PM #248You might have miss heard it. Ngayon lang ako nakarinig ng Hydrogen for tires. Its flammable and not recommended.
Maybe the right gas is Nitrogen. Its inert and stable even at high temperature thereby a stable tire pressure. Its costly though and commonly used on cargo trucks carrying heavy loads as their tires easily overheats. Same goes for race cars.
Cheers..........
August 9th, 2009 02:33 PM #249
hydrogen gas molecules are too small and just like in an ordinary balloon filled with hydrogen (or even helium for that matter, since the molecules are small just the same) the gas will seep out in a few days and the result will be a flat tyre. hydrogen gas molecules are so small that even stainless steel tanks and pipes used for containing and transporting hydrogen need to be replaced every few years as they become logged with hydrogen gas, a situation called hydrogen embrittlement. this situation results from hydrogen gas molecules seeping through the molecules of the steel, causing the steel to lose its strength. and rubber is more porous than steel!
i think you mean nitrogen gas. air is already 78% nitrogen.
August 10th, 2009 05:35 PM #250
aw... parang nitogen nga.hehehe sorry... P50 ang pa hangin di2 ng nitrogen...
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
