Page 26 of 42 FirstFirst ... 1622232425262728293036 ... LastLast
Results 251 to 260 of 420
    Feb 2009
    #251
    Yes sir, it is Nitrogen because it is an inert gas. It displaces oxygen that's why when your tire becomes hot there will be no tendency that it will blow out. Never never inflate your tire with hydrogen because it is highly flammable. Please be careful sir.
    May 2009
    #252
    Yup its nitrogen sir! pero mahal pa din dito sa shaw 100 per tire grabe. hindi pa yata pwede pag samahin yung normal air tsaka nitrogen....
    Feb 2009
    #253
    Yes sir medyo mahal nga dahil 100 pesos talaga per tire but worth naman. Don't think about the initial cost Bro think about your safety and the comfort and other benefits that you will be getting when you use nitrogen. Ordinary air will sip out easily from the tire that's why all the car manufacturer are recemmending to check your tire pressure often, if possible every time you fill up your gas. But when you are using nitrogen its not. The comfort hindi masyadong matagtag bro. You try it guys, with the same pressure that you are using with the ordinary air then compare it. Mixing nitrogen with ordinary compressed air will not do good bro. It is recemmended that you have to bleed the ordinary compressed air and they will change it with pure nitrogen. Mga bro if I am not mistaken nitrogen is being used to inflate airplane tires. Imagine yung init na yan when the airplane lands, kung ordinary compressed air yan sigurado sabog yan. Yung sa mga racing car ganun din. Kasi nga inert gas yung nitrogen it will displace oxygen sa loob ng tire mo, so kung yung tire mo will be generating/produces heat hindi ito sasabog. The worst scenario you will have is only a flat tire at dahan dahan ito hindi bigla, so at least safe ka pa rin.
    Aug 2009
    #254
    ^^san pwede magpa karga ng nitrogen sa tire?
    Aug 2009
    #255
    Quote Originally Posted by Pearl Green View Post
    aw... parang nitogen nga.hehehe sorry... P50 ang pa hangin di2 ng nitrogen...
    saan yang pakargahan ng nitrogen?
    Jun 2006
    #256
    Nitrogen is an inert gas. Air is 78% Nitrogen.
    The reason(s) why airplanes use Nitrogen on their tires is to prevent icing. Air consists of 20% oxygen. At altitudes of almost 40,000 feet, air temp can get as low as -50. That can freeze the moisture naturally present in air and cause pressure imbalance. Nitrogen's freezing point is well over that so no danger of icing which can burst the tire upon touch down.
    so, unless your car flies 40,000 above sea level, you don't need this.
    Most of all, how do you know that they're really loading Nitrogen Gas and not just compressed air?
    #257
    ^ titikman??
    seriously, that's a very good point, considering na hindi mu naman nakikita yung kinakarga, Yes it comes out from a what-they-call-nitrogen replacing machine pero you can't really tell right?
    Jun 2006
    #258
    Nitrogen is colorless, tasteless and odorless.
    Aug 2009
    #259
    Quote Originally Posted by Horsepower View Post
    Thanks for that good point...
    Jun 2009
    #260
    depende if asan makakarga ng nitrogen if may offer cla.. ang nagoffer sakin dito sa cebu ay petron banilad, P50 per 30 psi...
Nitrogen for Tires [Merged]
