Page 77 of 86 FirstFirst ... 2767737475767778798081 ... LastLast
Results 1,521 to 1,540 of 1708
    Jan 2016
    #1521
    This is the photo of the LG dual inverter watt control with price tag.
    Really huge difference, it's 5.6M
    Split typa ac sa abroad pa bibili? Diplomat!
    #1523
    errr...
    what's the conversion factor into pesos, po?
    tama ba, about 19.7K PhP. ?
    compared to 35K local here?
    Feb 2019
    #1524
    errr...
    Yes 19500 pesos plus shipping fee around 120 dollars.
    #1525
    for a while there, i thought it cost 5,699 pesos only...
    ikaw kasi.
    i was about to order several...
    May 2019
    #1526
    Ang laki ng kuryente namin, umabot ng 8K+.. Yung normal 3.5K to 4K lang.. Inabot 11K ang quotation para ma-relocate ang compressor.. Magpapa check pa ako sa iba, duda ako sa quotation (kakalinis lang ng aircon last month).. Baka kasi sinamantala napaka init kasi.. Pero good thing hindi ako siningil kahapon sa inspection.. Hehehehe [emoji1308][emoji16] Php 350 din ata yun..
    EDIT: nagagamit naman namin pero dating 21 hours, 12 hours na lang baka kasi bumigay pag isagad.. 9pm to 9am lang nakasindi ngayon.. Hindi pwede kapag sobra init, baka dun bumigay yung compressor..
    Mag update ako kung happy ending itong issue ko..
    Mag-update din ako sa month end about electric bill kung malaki naitulong nung relocation sa kain ng kuryente..
    UPDATE: Nakalimutan ko pala mag-post ng electric bill last June.. Mahal pa din kuryente namin [emoji28] pero baka mas mahal lang talaga ang singil ngayon..
    Based sa graph ng June, July 2020 VS. June, July 2021 mukhang may improvement sa KWh usage namin..
    Naka 20 hours aircon pa din kami same time 9am up to 5am.. Tingin ko, nakatulong nga ang relocation ng outdoor unit nung aircon kaysa sa dati niyang puwesto na wala masyado ventilation..
    #1527
    when one acquires a home aircon that really, really makes it so much more comfortable inside,
    one has to watch his aircon hours carefully.
    the temptation for 24/7 is so very... tempting.
    dalawang 1.5hp ang gamit?
    Feb 2019
    #1529
    ikaw kasi.
    Sorry about that forgot to put an "M" after 5,699 but still cheap at Php19,5k
    Feb 2019
    #1530
    Is the delfector plenum installed correctly in the condensing unit since it is near the wall
    #1531
    alin,
    yung embudo ng ulan?
    i don't know.
    "i have seen worse."
    in some models, the fans point upward, as if they were designed to take advantage of the rain...
    let us wait for knowledgeable person to offer enlightenment.
    Jun 2005
    #1532
    Kung my bubong din yan sa itaas, iikot lang yubg mainit na hanginm baka overheat uli. Medyo similar yan dun sa nakakabit sakin pero window type itong akin
    Sa tubig naman, pabutasan mo na lang ng konti sa ilalim para magdrain tubig.
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    sa itsura palang mukhang mainit
    Sep 2010
    #1534
    Sorry ano ang deflector plenum? para saan to? Pang catch ng rain?
    Feb 2019
    #1535
    The deflector function to move the hot air blowing from the condensing unit upwards since it is very close to the wall.
    #1536
    That's not efficient. No other location?
    Sep 2010
    #1537
    Oh ok. I don't know how a compressor works, but I assume it's ok when that catches rain water & maybe flood it?
    Jul 2013
    #1538
    I'm sure may drain yan sa ilalim
    Jan 2016
    #1539
    It looks to me like the deflector is not only useless but also impedes air flow compared to none. If the deflector wasn't there, won't air also escape sideways aside from upwards?
    Same thoughts…. the air will flow like a cross sign perhaps if no deflactor…
    Also, i doubt if there’s benefit of having it… siguro parang accesories sa sasakyan, para maganda tingnan?
Split Type Aircon: Which is best?
