Page 6 of 86 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 1708
    #101
    Does anybody actually measure the temperature of their air conditioned room? I just adjust the temp &/or fan speed according to my comfort level.
    Jan 2009
    #102
    On our Panasonic inverter, I keep the temp at 26C and everything else in auto (mode, fan speed and air swing). We're more for comfort cooling and economy since we took home my now 2-week old baby from the hospital. For those two weeks, the A/C has been practically turned on 24x7.
    Aug 2010
    #103
    [SIZE=3]guys, normal lang po ba na nagmomoist ung copper tube na nakakabit sa outdoor unit? i mean nakaloop kc ung sobrang copper tube sa likod ng outdoor unit den sa pinakababa ng naka.loop na tube may build up ng moist minsan tumutulo pero mahina lang nman.. sa gumagamit din po ng samsung inverter 1.5hp, ano po ung rubber insulation na ginamit sa n u 1/4 & 3/8 din ba? nagdagdag kc ako ng bayad for thicker rubber insulation dw according dun sa quote nila sken pero 1/4 & 3/8 lang nman ung ginamit which is standard lang. [/SIZE][SIZE=3]anong brand pala ng rubber insulation ung ginamit sa unit nu? and kusa din bang namamatay ung inverter ac pagka na.reach nya na ung desired temperature na nka set den automatic na bumubukas pagka tumaas ung temperature? sa mga samsung inverter users, umaabot ba ng 16 ung temp ng room nu pagka sinet nu sya sa 16? db may current temp display ung indoor unit ng samsung.,saken kc pinakamababa na is 20 kahit nka set sya sa 16 and to think na 1hp lang ung nirecommend ng nag survey smen pero 1.5hp kinuha q. nka powered on sya for 6 hrs and minimal lang ung room activity pero hanggang 20 lang talaga ung pinaka.,mababa na nagdisplay sa indoor unit na lcd.nde kaya defective un pagka ganun? tia.[/SIZE]
    Jun 2006
    #104
    Has anyone tried the Carrier Zen multi-split or any multi-split for that matter?
    We're renovating an ancestral house and my dad wants to keep the 1960s look so we're planning to install multi-split and tuck the condensers at the back.
    We're probably gonna need two sets (around six rooms).
    My question is, is it really a good idea to have a multi-split rather than single split AC? With single split, the back of the house would look like propellers ready to lift the house with six or eight condensers.
    TIA
    Oct 2008
    #105
    mas prefer ko talaga window type para incase masira at kailangan palitan hassle free
    slit type kac ung tube nya dapat mo itago sa loob ng semento or sa loob ng ceiling kaya incase tumulo o magkaproblem ang dami mo tatangalin.
    ang aircon kasi every year halos meron bago. slit type parang pangpermanent na.
    Jan 2009
    #106
    My only two incentives for going for split-types are:
    a. Super silent operation
    b. Comes in inverter models
    #107
    Quote Originally Posted by Horsepower View Post
    TIA
    A few years ago, naglabas ang LG ng multi-split (1 outdoor = 2 indoor units). Pero parang hindi yata nag click. Parang wala na sa market now. Don't know what was the problem of this kind of setup.
    Anyway, pwede mo naman gawing sampayan area yung likod na puno ng outdoor units Kabilis sigurong matuyo ng mga sinampay mo dun :bwahaha:
    May 2005
    #108
    TIA
    Are you referring to several indoor units sharing a single outdoor unit? AFAIK, for Panasonic's version of this multi -split, the outdoor can accommodate 3 HP so its either 2 indoor units (1.5 HP each) or 3 indoor units (1.0 HP each). So if you have 8 to 10 units inside, it would still look like a ventilation room.
    You can have the condensers scattered around the house. Install them on the first level (don't hang on near the 2nd level bec. they will be visible from the outside) unless flood is an issue.
    Sep 2005
    #109
    Carrier has a multi split outdoor.. 2HP or 3HP.. for 2 units or 3 units indoor.. this was released specifically for one condo in the fort.. almost all units there have this..
    Jan 2003
    #110
    why is it that most installers prefer Kolin for split type? ok ba yun?
    Jun 2006
    #111
    Thank you for your insights.
    I have decided to just insist on Window-type ACs. I reckon that it being situated in an island, maintenance of splits would cost a lot for a house that we just live in 5-10 days in a month. As a consumer, I predictably would have to shoulder the travel and lodging expense of the serviceman, aside from his PF. It also occurred to me that I don't want to waste the little time we spend there repairing or having the splits serviced. With Window-types, I can just pull it out, diagnose it and bring it to the mainland if I can't fix it. Buy a spare and use it.
    After this renovation, we're going to do another project. That's where I think it's more viable to use splits. I probably would stick to single-split though. I realized that if the condenser of the three splits conks out, there'd be three rooms without an AC. That can be a disaster for some. In a beach island, it can get really humid at times.
    *Badsekktor: I think Kolin sucks. Haven't encountered a good unit yet and an owner who swears by its durability.
    Now, if you're the installer, you'd like an unreliable brand like Kolin because that'll mean repeat jobs for you.
    Jan 2003
    #112
    hmm... sayang. late ko na nalaman... i've already purchased the unit. lets wait and see... 5 yrs warranty binigay sa akin nung seller
    Aug 2005
    #113
    Sirs ,we're in the market for a split type inverter a/c. We are currently using a 1hp window type carrier a/c. We're choosing between panasonic econavi and carrier xpower. Usage is between 12-18 hours a day. Ano po kaya nag mas matipid and reliable sa dalawa? Saw an old ad of carrier xpower with 53% savings vs. Other inverter brands tapos tong panasonic econavi with 65% savings. Real world experiences from real users(not sales reps) would give us meaningful insight. thanks po.
    Jan 2009
    #114
    Anybody use a Samsung 2.5HP inverter split? We need one in the living room.
    We have a 1 y/o Panasonic 1.5HP inverter split in the bedroom and so far, it has never failed us. Although, there seems to be some rust forming on the outdoor unit's base, right below where the piping is connected (due to condensation). I think a bit of rust converter and a few coats of anti-rust paint should prevent it from spreading.
    I'd very much want another Panasonic for the living room if it were not for the steep price tag. I can get the Samsung for 50k (12 mos. zero interest) with free installation/piping up to 15 feet. The Panasonic equivalent is about 56k and the installation is NOT free (minimum service fee is approx. 7-8k).
    Bang-for-buck, I think Samsung's the winner here, but will it be as good as the Panasonic in the long haul?
    #115
    I just got a Panasonic Deluxe Split type aircon 2.5hp for 46.1K at my suking appliance center here in our place. Try to check prices from other stores. Mahal talaga sa mga mall based appliance stores.
    Signature
    #116
    Horror SAMSUNG split type aircon.
    6/18/2011 bought a Samsung split type aircon 2.0 horsepower
    6/23/2011 unit was delivered, but due to recent strong storms unit was installed on 6/28/2011
    6/30/2011 unit automatically shuts down after 5 minutes. no cooling and unit is blinking. reported to Samsung
    7/2/2011 unit was inspected and compressor was defective. They advise new unit to come in 3 days. That afternoon Samsung called asking for the serial numbers for which I said I will look but she told me that she will call back which she did not. But nothing happened.
    7/12/2011 Already not happy. I called them in the morning . They said the person in charge is not in her table. They got my number and cellphone and will return call. By 4:45 pm, no one called, so I called them again. This time, the lady told me after being on hold for 5 minutes that I should call them back again. I said "what, call back again?" Yes she said, she cant do anything except for me to call them back.
    7/13/2011 930am I called them . really angry already. I told them that I need to talk to someone who knows what she is doing. Then I narrated the story from day one. Then she said my sales invoice was of poor quality that they could not discern anything. I told them if that was keeping you then why did you not informed me earlier. Then I demanded for the supervisor, she has the nerve to negotiate for a "repair". I told them this was a lemon unit. I asked for a new unit.
    7/18/2011 The new unit arrived, but since the delivery guys have no tools and technical know how to remove the said unit . it was agreed to post pone another day. The new unit was not left behind the delivery brought it again with them.
    7/19/2011 The technician who were supposed to arrive to remove the old unit is not yet here as of 3:45 pm.
    to be continued.
    Jun 2006
    #117
    Samsung really sucks that's why I stay away from their products like a plague (except their phones perhaps, my brother had sturdy samsung phones).
    Jun 2006
    #118
    Were using Samsung inverters in the office. Ok naman. Really keeps electrical cost down. No complaints with the unit. The dealer's service sucked big time. Just cant remember the company name.
    #119
    to continue the Samsung split type inverter aircon 2.0 hp
    7/19/2011 technician came and remove unit. (around 5 pm)
    7/20/2011 my request for a "brand new" unit came in 2 boxes. Before I signed the invoice, I got curious as to whether there could be a mix up in the model. So I ask for the blower unit to be opened. And lo and behold, I saw a dirty unit. They tried to explain it as dirt that can be removed with a cloth. So they did and result was shabby but acceptable. So then I ask to open the compressor. And I saw 2 corners (topside) with deep scratch, first was about 1 inch long and the other 1/4 inch long, supposed to be powder coated but now colored black as the white powder coating got scratched. And then I saw 2 very long scratches (more than 18 inches long) on the top metal or plastic cover ( not sure if plastic). The unit were all sealed with three straps and several industrial type staplers when they arrived this morning before I opened it in the presence of the delivery guys. So I refused to accept and the units were sent back.
    My claim to them is they tried to sent me "refurbished units" and not "brand new". For them to claim these as "brand new" would imply that there was no quality control on their part.
    If I were to treat my customers the way Samsung treats me, I would be out of business already. (original quote from me, I think)
    I think a refund is in order. I want my money back.
    Jun 2010
    #120
    Guys any experience with LG units? Just got a good deal on a 2.5 hp non-inverter type.
Split Type Aircon: Which is best?
