Page 56 of 86 FirstFirst ... 64652535455565758596066 ... LastLast
Results 1,101 to 1,120 of 1705
    Mar 2013
    #1101
    wag kayo gagamit ng EXACT size inverter AC. baka full load lagi compressor, sayang lang. ideally oversize dapat by .5 to 1hp. bibilis sya palamig then yung pag maintain ng temp nasa 20-50% lang ng compressor magagamit.
    case in point my room is about 10 sq mtr only, used to pay 4-5k using .75 hp panasonic non-inverter; replaced it with 1hp fujidenzo inverter, immediately went down to below 3k average (went as low as 2.4k pa nga eh). upgraded to 1.5hp kolin inverter, average is now in low 2k, plus 14-20 hour average (iba sked namin ni gf minsan) and 24/7 pa during weekends vs 10 -14 hours noon non inverter pa ang gamit.
    i cant use current reading as a benchmark kasi sobrang baba na dahil bihira kami nasa bahay recently, so sobrang baba na talaga.
    This +100
    Sent from my SM-N950F using Tapatalk Pro
    #1102
    Agree. A 0.8 hp will work in my room but I'm getting 1 hp. A 1.5 hp will work in my living toom but I'm getting 2 hp.
    Medyo masakit yung 1.5 to 2 hp because there's 10k difference between the two (since it's really closer to 1.33 hp than 1.5) but in the long run it's better in terms of consumption.
    Nov 2007
    #1103
    What's the lowest hp of inverter-type ac? I always see 1hp pero parang too much for a small bedroom na almost as big as a queen-sized bed lang.
    Sent from my ASUS_T00J using Tapatalk
    Panasonic and LG have 0.5 and 0.75 HP models afaik.
    May need pa naman mga <1HP AC models esp sa mga maliliit na rooms mas lalo sa mga condo. We had a 0.5HP for a 6 sqm bedroom sa condo and worked great.[emoji16]
    #1104
    When computing for aircon size, consider all heat generators in the room - kitchen appliances (ref, stove, etc), TV, ambient sunlight from wall-to-ceiling windows or sliding doors, and of course extra people.
    #1105
    isa pa yan bro na winawalambahala ng mga nagbebenta ng AC sa ibang stores. pag na assess nila na .5hp AC lang kaya bilhin ng buyer, bebentahan parin knowing that it wont be enough for a 15 sq meter room with all family members in the same room. pag madalas ka dumadaan sa mga stores na ito, makaka tyempo ka talaga ng "sales talk" LOL
    Mar 2004
    #1106
    The best way to convince someone to get a window type air conditioner is to let them buy a split type air conditioner ...
    Jun 2015
    #1107
    Ok. So, 1hp it is.
    killing me softly.
    #1109
    Haha...1st hand will always be more convincing.[emoji4]I've seen too many upgrade, only downgrade back.[emoji17]
    Why would they downgrade?
    #1111
    Collateral damage from maintenance, leaks, repeated repairs, replacement (the chipping, masonry work, paintwork, floor & wall rehab, etc) can consume patience & tolerance. They downgrade to the real 'upgrade' of simplicity & practicality...the window.[emoji4]
    #1112
    Basta ako personal experience ko mas okay split type. We used to be all window-type before. Ngayon isa nalang yung window type namin, nasira pa. So now I have to buy 3 aircons instead of just 2. [emoji23]
    Super mas tahimik when I switched from window to split. Also the aesthetics of the room, sobrang mas malinis tingnan.
    Never naging bothersome for me maintenance. Tagal na rin naming naka-split type sa bahay and never ko naexperience yung mga hassle na sinasabi dito. Kaya nga kung first-hand experience ang best basis, ok na ok ako sa split type.
    Nov 2017
    #1113
    Mukhang me bad experience si travajante sa split type.. Well look for good installer and invest on good quality foam insulation sa piping.. Use 1" size pipe as drain pipe. Importante kung maiiwasan yung mahabang linya.. Tama ka mas malapit yung blower sa condenser mas maganda [emoji16]
    Nov 2014
    #1114
    They both have pros and cons. For me, split type is for aesthetics. It's just weird that before my split type would leak every six months while I never had a problem with window type even if I don't have it cleaned for years. What I don't like about window type is the hole in the wall (which is minor).
    Quote Originally Posted by maxpedition View Post
    I have one split type gumamit ng 40+ feet of tubing dahil sa likod ko pinakabotnyin outdoor unit para hinde nakikita sa harap ng bahay
    #1116
    My exposure is a bit different. We get called to restore whatever the AC guys can't put back post-repair/replacement.[emoji17]
    #1117
    In other words you get called when there's a problem. Which is why our experiences are different.
    And mga assuming mga naayos ni Trava wala ng naging issue so walang problema pala talaga split type a/c
    #1119
    There's no fun in fixing flaws caused by those outside our coverage. Hence, we try to provide detailed guidelines for the AC guys to comply w/ on new installs....to prevent split-trauma, sir.
    #1120
    Nah, I just shared the pros, cons & measures needed. We even specify a minimum of 1.25" PPR drain, not blue. Splits are ideally installed along perimeter walls, where possible, to avoid lines running thru ceilings. If unavoidable, the insulated lines must be laid on gutter trays or thru pipes...I can go on & on.
    Though I find joy in those of others, leak therapy isn't fun. Leaks can leave indelible scars, literally & figuratively.[emoji17]
    Please don't get me wrong...I'm not anti-anything here. Just sharing to help prevent splitphobia.
Split Type Aircon: Which is best?
