Page 46 of 49 FirstFirst ... 364243444546474849 LastLast
Results 901 to 920 of 1708
    Jun 2005
    Kung my bubong din yan sa itaas, iikot lang yubg mainit na hanginm baka overheat uli. Medyo similar yan dun sa nakakabit sakin pero window type itong akin
    Sa tubig naman, pabutasan mo na lang ng konti sa ilalim para magdrain tubig.
    Is the delfector plenum installed correctly in the condensing unit since it is near the wall
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    sa itsura palang mukhang mainit
    Sep 2010
    Sorry ano ang deflector plenum? para saan to? Pang catch ng rain?
    Feb 2019
    The deflector function to move the hot air blowing from the condensing unit upwards since it is very close to the wall.
    That's not efficient. No other location?
    Feb 2019
    Im not sure with the owner but probably there will be other options for condensing unit location but farther than this one.
    Sep 2010
    Oh ok. I don't know how a compressor works, but I assume it's ok when that catches rain water & maybe flood it?
    Jul 2013
    I'm sure may drain yan sa ilalim
    Jan 2016
    It looks to me like the deflector is not only useless but also impedes air flow compared to none. If the deflector wasn't there, won't air also escape sideways aside from upwards?
    Feb 2019
    Nope the air will flow directly into the wall and then bounce back probably some air would go sideways that's why deflector is installed to make way for the air to go upwards.
    Same thoughts…. the air will flow like a cross sign perhaps if no deflactor…
    Also, i doubt if there’s benefit of having it… siguro parang accesories sa sasakyan, para maganda tingnan?
    i wish the owner would chime in and assure us,
    "guys, i read your concerns and theories. i assure you, lumamig ang aircon namin nung kinabit namin yang venting aid na yan."
    With that fix, its not exactly engineering.
    Obviously the condenser fan has to work extra. More work means higher power consumption. MTBF for the fan is lower by a higher margin.
    Aug 2004
    Baka nagreklamo ang kapitbahay hehe
    Sabi nung installer ko may mga cases daw ng away dahil nakatutok ang condenser fan sa bintana ng kabilang bahay [emoji1787]
    Sent from my SM-A605G using Tapatalk
    Apr 2012
    What's the difference sa Standard na Inverter AC vs sa full DC inverter?
    Sent from my SM-A507FN using Tapatalk
    basic inverter ac only have the compressor working on dc, while its other components like blower fan, outdoor fan are ac.
    full dc means all major components are dc,
    Sep 2010
    & full dc means it would be more expensive but it consumes less electricity?
    Mas mahal yun meron wifi control. Not sure about the pricing differences.
    Full dc means it can throttle down low in the evening. If you're just one person making 80w of heat. That's what's theoretically the lowest wattage. But there are other heat sources like walls and maybe other live human beings.
    Feb 2019
    So far the cheapest split type i inquired is TCL Gold less than 30K including installation for 1.5hp unit.
    Aug 2021
    Thanks for this. Checking TCL reviews now.[emoji846]
    Sent from my SM-A315G using Tapatalk
Split Type Aircon: Which is best?
