Page 53 of 86 FirstFirst ... 34349505152535455565763 ... LastLast
Results 1,041 to 1,060 of 1708
    Jan 2008
    #1041
    Sa split type 2 pa lang un natry ko. Mitsubishi at carrier. Mas ok un Mitsubishi. Mas tahimik un outdoor unit. Tsaka wala din nasisira. Parehong 10hrs a day kung paandarin. 5yrs na un mitsu, 9 yrs na un carrier. 6months ago nasira un main board at receiver ng indoor unit ko sa carrier, sulit na din naman.
    Sent from my Redmi Note 5 using Tapatalk
    #1042
    On a side note: travs you're the only construction guy I've encountered that doesn't drive a pickup or SUV. [emoji23]
    OT.....I've the old reliable I refuse to let go of, good sir. The Daikin of automobiles.[emoji4] It has never complained...neither have I. When my routes won't require me off road, I take the fun smaller ones....less road footprint, less guilt in adding to the bad traffic.[emoji4]
    Jun 2005
    #1043
    Yes I generally agree which is why Daikin and Panasonic were my top choices. But looking at spec sheets, the LG looks like a winner.
    I'm wondering if the LG is excellent on paper but loses out in practice to the Japs. Just as the Elantra 1.8 makes more power and costs less than the FD Civic 1.8 but we all know which is the better car for the long term between the two. Is the case the same for aircons?
    Compressor of my LG inverter went kaput on the 15th month.
    Replaced compressor under warranty but i paid 12k to have the damn thing installed. Di raw part ng warranty installation. Just the part.
    Sent from my MI MAX 2 using Tapatalk
    #1044
    Quote Originally Posted by sirkosero View Post
    This is where split can hurt...install, repair & reinstall fees. Cleaning can be a chore, too. Skeds have to be synched as they'd have to do this in-room. This can be a challenge for 'help-less' households like ours, someone needs to be home to wait em out.
    Window installs & cleaning are both DIYable, quick & easy. Should it conk out, one can just grab an identical model & slip the unit in w/o frame/casing removal.
    #1045
    maganda nga sa window type madali linisin, every month binubugahan ko lang ng tubig. maiiwasan mo mag accumulate yun dust at maging mud or moss; tapos sa filter naman bi monthly ang linis. na eextended ko pa yun time bago magbaklas ng AC unit for full cleaning service.
    Mar 2004
    #1046
    *jut
    Get the Daikin ... It's highly recommended ... They have and are soon to overtake Samsung as the number one in sales of commercial installations ...
    AFAIK, Daikin does not market most of their models in appliance stores ... They prefer to sell directly thru installers and contractors ...
    Jan 2012
    #1047
    Daikin is big in Japan. Galing Japan ba yung Daikin satin?
    #1048
    I need an aircon for my room. Already has a hole for a window type but my contractor can cover it up and convert to split type.
    Panasonic's 1hp split type inverter is 26k including installation. Their window type inverter is 28k.
    Any reason why I should go for window type over split type?
    If split type, compressor will be at the balcony right beside the split type ACU so maintenance shouldn't be an issue.
    the only reason i would go split-type, is because i can't install a window-type.
    window-type is cheaper and easier.
    it's easier and cheaper to install, service, and replace.
    when the split type in the workplace malfunctions or needs cleaning, it's a commando operation.
    when the window-type needs looking into, they just pull it out, and return it when it is fixed. faster fix, too.
    but i am sure, you already know all these.
    so why are you considering split type?
    #1049
    my aircon man emphasizes,
    make sure the drain system is not clogged. if clogged, rust follows fast.
    #1050
    Because it looks better, is more efficient, and is cheaper (surprisingly the inverter split is cheaper than the inverter window).
    Like I said, if it needs repairs/maintenance once a year, then that's one day of hassle. The remaining 364 days, I get to enjoy my better looking room and enjoy my electricity savings.
    Jun 2005
    #1051
    During the time the LG compressor went kaput, downtime was 3 weeks.
    Main problem ng split type is workmanship. Yung fittings madalas nagkakaleak ang nauubos right after the 3 month install warranty. Those flarws also act up sometimes. You dont encounter these problems with wondow types.
    Im planning to replace the split type with window.
    #1052
    Even assuming 3 weeks, it's not that big a deal since I don't need the aircon all the time. 49 weeks of better looking and more efficient operation still sounds like a good tradeoff.
    And that's also why I want to get a higher quality aircon - to avoid breakdowns in the first place. My National aircon in my room hasn't needed any repairs since it was installed 3 yrs ago, and the aircon is 20 yrs old and has moved 3 houses.
    #1053
    Keys to splits are to have the least number of seams, have oversized drains & the shortest possible route from indoor to outdoor. Those are where leaks pop 1st.
    Ironic how the love for window usually develops from the hate for splits....Love at 1st sight or sound can be shortlived.[emoji852]
    #1054
    experience is the better teacher.
    'swhy there are voters for split, and there are preferers for window.
    #1055
    The nice looking Panasonic window type inverter doesn't fit my pre-cut enclosure. 500mm cutout vs 560mm width for the Panasonic. The Hitachi fits but looks hideous.
    Tapos magkalikod lang talaga yung split type and condenser so very very short tubings, so less chances of leaks. Really leaning towards split type now.
    Just deciding on the brand. Will visit a store later, eto prices nila online (free installation):
    LG - 27k
    Panasonic - 29k
    Daikin - 30.5k
    #1056
    my colleague had house originally split-airconed.
    had to destroy part of the wall after a few years, as they had to look for the leak. the straight, un-coupled tubings were (belatedly bad decisionedly) embedded inside the wall, about a dozen feet or so. the other half of the split was just outside the wall, sitting on the terrace.
    window type na siya ngayon.
    #1057
    LG - 27k
    Panasonic - 29k
    Daikin - 30.5k
    What's the floor material under the AC, sir? Wood, Laminate or Ceramic Tile?
    #1058
    In the room? Laminate.
    #1059
    Oh, laminates. ...Careful w/ spills. They can bloat. Have you seen how service guys clean splits? They protect the wall with a sheet of plastic curtain that funnels onto a pail. That's the collector for the water they spray onto the indoor unit. Accidental spills aren't uncommon. And, should the unit leak, expect the floor to be collateral damage. Just pay a lil extra attention.
    All that said, if you're still leaning split, stay w/ Daikin; limit your weld seams to 2, if possible; line an oversized properly sloped drain; insulate well & do not embed em lines. Oh, ideally no fixed mounted appliances under the wall unit....And don't ever go cassette....You should be ok. If you fear the hassle, you can cut the journey & go Hitachi window....that's a well rated one.[emoji4]
    #1060
    Really not digging the Hitachi's looks:
    Also only has a 12.3 EER.
Split Type Aircon: Which is best?
