Page 19 of 86 FirstFirst ... 91516171819202122232969 ... LastLast
Results 361 to 380 of 1708
    #361
    okay sir, so useless din ang power saving device pag residential. sa industrial kasi ung mga capacitor bank ba un? yan nakikita ko na gamt nila.
    Same principle. Depende kasi sa location mo at circuit ng meralco. Meron sa ibang lugar up to now .83~.87 power factor, dun makakatulong ung power saver.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    #362
    Quote Originally Posted by jay2 View Post
    Hitachi is also a very good brand. Higher kjh than other Aircon and assemble sa subic not China.
    Regarding power saving devices my
    opinion is use a kilowatt meter in measuring not clamp meter to know kung effective talaga sya. Kilowatt meter yung kuntador and not ampmeter.
    Mali pards, para malaman mo na effective agad power saver ang dapat mo i measure ung actual current with and without power saver. Hirap sukatin sa kwhr meter dahil dial indicator at matagal pa bago ka makaestablish ng data.
    Oct 2011
    #363
    Quote Originally Posted by brainmafia_310 View Post
    okay, noted sir.
    Aug 2004
    #364
    mura nga kay Voltz. sikat din yan sa ibang forums.
    May kilala bang LG accredited installer si Voltz? Sya yung sa Cash and Carry diba? Planning to get a 1HP inverter kasi
    #365
    JohnM, nakalimutan kita replyan sa PM.
    Anyway, I am not sure, Pero dapat meron since accredited reseller yan.
    isa pang mura is in Shangrila Plaza. Go to Sight and Sounds. Meron din sila a/c units na mura. LG was 27k yata yung 1hp last i ask.
    #366
    ^ Try also Twin Marks in Mandaluyong. We bought some ACs from them and price was okay. Sulit.com.ph - Twin Mark Aircon Supply | Edlyn Salubayba (myaircon) Philippines
    Aug 2004
    #367
    Nice prices! :jawdrop: Do they also install vinj?
    #368
    They can refer you to a sister company for the install works AFAIK; or you find an authorized installer. They also give additional discount if you pick-up from their store directly instead of opting for delivery.
    Jun 2011
    #369
    meron sir.. cya din ang kumuha ng installer...
    GRABE SIR LAKI NG TINIPID ng kuryente ko sa LG na inverter I.S. model... na 1.5hp... 50% savings compare sa non inverter...
    #370
    If you have lots of inductive load, motors et al, then you may need to use the power factor correcting device which is basically a bank of capacitors, as we are being charged for the true power kw and not for the apparent power kva....
    Oct 2011
    #371
    What is your ideal thermostat setting when using your aircon at the office and at home? Your thermostat setting is also a factor in dictating the coldness and more importantly the cost of your monthly aircon electrical billing.
    Sep 2009
    #372
    sa room ko sir nasa COOL mode at 26c, auto fan speed..... sobrang lamig na,
    Oct 2011
    #373
    anything above 25C for me, I find it not cool enough.
    Sep 2006
    #374
    Panasonic Inverter 2.5hp. Ang setting ko 23C tapos fan speed 2. Pag matutulog na ko auto na yun fan di ka na pwede walang comforter or blanket matulog.
    Jun 2011
    #375
    me naman at first 18 ang setting, then pag super lamig na lalagay ko lang sa 26... LG inverter a.c. ko
    bro. retz ano pala brand a.c. mo?
    Jan 2009
    #376
    26-27°C is the norm in my home.
    Oct 2011
    #377
    Sir manikis, sa office daikin gamit namni na split type ceiling cassette.
    #378
    Daikin? Alam ko close na eto or naghiwalay na sila ng daikin-allen. Pootek hirao ng support nyan sir.
    Oct 2011
    #379
    ibang contractor naman ung nag mamaintain and cleaning sa aircon.
    Jan 2003
    #380
    I usually set it at 22C. Then turn off at 6am. Once I maxed it out at 18, my room thermometer registered 19C. Using a non-inverter Panasonic Split Type.
Split Type Aircon: Which is best?
