Page 22 of 86 FirstFirst ... 121819202122232425263272 ... LastLast
Results 421 to 440 of 1708
    Oct 2011
    #421
    pampainit yan sir sa lamig ng LG airconditioner.
    #422
    Yung Panasonic split type namin sa room, ang baho minsan. Kahit kakapalinis lang amoy mabaho pa rin. Ano kaya ang cause?
    Yung water drain kasi sa down spout ng roof naka shoot, pwede kayang eto ang cause?
    Signature
    Mar 2004
    #423
    That's most likely the case. Probably molds.
    Oct 2011
    #424
    Sir boybi, hindi ba nagbabara or may tumutulo doon sa fcu mo?
    #425
    Anong FCU?
    Signature
    #426
    Molds sa piping or housing yung naiisip ko... check also the area near the outdoor unit i'd surmise. Check if the pping flows well...
    #427
    If molds, di ba dapat mawawala na after aircon cleaning?
    Signature
    Binubugahan ba nila yun drain pag nag cleaning? we have the same set up, nasa down spout din nakasaksak yun drain ng split type..wala naman mabaho...
    #retzing
    #429
    Binubugahan naman siguro.
    2yrs palang itong aircon.
    Signature
    Anong Amoy? Baka amoy plastic lang (brand new) smell
    #retzing
    #431
    Amoy kakatapos lang mag-ebs
    Signature
    Jul 2013
    #432
    hindi kaya ng lysol spray? molds yan.
    #433
    Spray ko sa room or sa fins ng aircon?
    Signature
    #434
    Don't spray the A/C; doesnt seem good to do that since chemicals pa rin yan. Try putting a deodorizer or uling in the vicinity of the aircon perhaps?
    Dapat. The smell is consistent or comes out only pag bagong bukas yung A/C? How about pag inopen mo in a high fan setting? If it comes out pag bagong bukas lang, possible it's condensation build up or water pooling somewhere (parang basang trapo). Try also, turning off the cool setting and putting it on "fan mode" for a few minutes before shutting off the A/C then observe pag bukas mo the next time.
    Baka naman banyo ni boybi pala yung naka-split type. :D
    Oct 2011
    #435
    Anong FCU?
    ung fan coil unit sir doon kasi bumubuga ng hangin. baka barado ang drain kaya balik ulit sa fcu and then mabaho ang buga.
    Sep 2009
    #436
    Itong carrier split type ko di na lumalamig? Kakalinis ko lang ng filter ganito na. Mag 1 week ng ganito. Dati sobrang lamig na kahit 25c lang. Pero ngayon 20c pinapawisan pa ako.
    Sent from my GT-I9505 using Tsikot Car Forums mobile app
    Oct 2011
    #437
    baka may leak undercharge na sir ng freon.
    Sep 2009
    #438
    Paano malaman sir kung freon nga yun? Checked ko yun outdoor unit, basa lang naman yun mga pipe which i think normal dahil malamig yun pipe db?
    4 month pa lang yun unit sir.
    Oct 2011
    #439
    sir may ginagamit sila dyan na pressure gauge sa discharge and suction para malaman kung tama pa ung pressure reading kung hindi, may leak na yan. pati ba accu pinalinis mo sir? kung hindi makuha sa linis at tama naman ung thermostat setting mo malamang may leak na.
    #440
    May nakita ako last time sa Sm Appliances.... Carrier split type OPTIMA 2.5 hp pero di sya inverter.... May sticker na mas matipid siya sa may inverter.... Mura lang nsa 44k+ siya.
    Sent from my HTC Desire V using Tapatalk
Split Type Aircon: Which is best?
