Page 157 of 169 FirstFirst ... 57107147153154155156157158159160161167 ... LastLast
Results 1,561 to 1,570 of 1687
    #1561
    +1
    No fancy features - not even an LED display for the temperature - but definitely solid.
    Sent from my PL2_sprout using Tsikot Forums mobile app
    Think Toyota.[emoji4]
    #1562
    Ano possible reason pag mabilis ang buildup ng gunk (yung parang jelly na biofilm)? Feeling ko hindi sa drain dahil parang wala namang bara.
    Normally sa WT, sa tubig yan na naipon sa base na di nagdi- drain.
    Check mo kung tumutulo.
    Jun 2015
    #1563
    I-monitor ko na nga lang. Kakapalinis ko lang kanina e. Binombahan din ang drain pipe. Obserbahan ko kung nade-drain nga ba nang maayos. Pero normally hindi naman totally nawawalan ng tubig ang drain pan di ba?
    #1564
    Normally kailangan nakatilt toward the back para tuloy tuloy ang pagdrip at di maipon sa pan.
    Kasi may option yan na may cap yung drain para makatulong to cool down the condenser, but the negative effect yung biofilm build up.
    Apr 2012
    #1565
    Any reviews with TCL aircon?
    Sent from my SM-A507FN using Tapatalk
    Mar 2004
    #1566
    If people read the installation manuals of window type airconditioners ... there's a maximum tilt angle limit ...
    #1567
    Ilan kailangan na clearance sa sides ng window type aircon? ok lang ba mga 1 foot na concrete per side and 2 feet sa back?
    Quote Originally Posted by manager View Post
    no obstruction sa likod.. that thing wil just overheat.
    #1569
    i think you just described an enclosed space.
    if the air in there does not actively move in significant volume,
    your aircon will overheat.
    Feb 2019
    #1570
    Have our aircon cleaned earlier as it is not enough to cool the entire room probably because of the high ambient temperature outside.
Split Type Aircon: Which is best?
