Page 168 of 169 FirstFirst ... 68118158164165166167168169 LastLast
Results 1,671 to 1,680 of 1687
    Jan 2009
    #1671
    Back in the 70's and 80's, the main failure points of window A/Cs were the metal base. They rusted through in a matter of a few years. The sweet spot was when they started transitioning to a plastic base. But eventually, in the name of efficiency and manufacturing cost-savings, they also started using materials that were relatively lighter and thinner (ie. coils, compressor), and then the trouble shifted to those parts.
    Nov 2019
    #1672
    Quote Originally Posted by LOLZ View Post
    I think may nabasa rin ako parang ganyan ang experience with their Inverter WT pero before pandemic pa kaya nagbabakasakali baka naayos na nila ung issue medyo nakakadismaya if until now ganyan parin lalo na if kelangan pa ng technician na baklasin un unit para mareset. medyo OT pero did you end up keeping ung carrier na WT ?
    Ilang ulit lumabas yung issue, binenta ko na sa willing mag ayos.
    Not worth yung effort na baklasin para ma reset.
    Ang mahal pa naman ng unit na yun.
    Nov 2017
    #1673
    two of our carrier window types sprung leaks. prematurely, i opine.
    sabi ng third-party repairman, "kung ganyan ang kalidad ng carrier, kuha na lang kayo nang china brand. siguro naman ay kasing tagal ang buhay niya, nguni at mas mura naman".
    hmmm...
    Strike 2 for carrier i guess.
    Quote Originally Posted by carxynogen View Post
    Ah i see, what model did you replaced it with ? Had good luck with the Hitachis(even though they have a reputation for moisture ingress issues) but it seems they made it worse lately atleast the specs on the nameplate suggests to be so.
    Nov 2019
    #1674
    Hitachi Inverter but na undersize ko (0.8HP), may issue lumabas na mag ice yung evaporator.
    Need ko pa patuyuin/melt yung ice para bumalik sa dating lamig buga niya.
    Yung ambient sensor kasi nasa malapit sa evaporator kaya akala niya malamig na room when this issue happen kaya pahinain/off niya compressor prematurely.
    Hindi ko napaayos since sobra din kasi gumagamit chikiting ko ng AC kaya siguro ganyan behavior niya.
    Lately, nag Panasonic Inverter WT na ako, no issue so far for 3 yrs ownership.
    My Carrier before, less than 1 yr lumabas nung issue niya, kaya mas happy ako sa Panasonic Inverter ko ngayon.
    Mas tahimik pa at closely similar yung noise level sa Split Type.
    Jul 2014
    #1675
    Ung sa amin, nalalaman ko na nagyeyelo kapag humihina ang lamig. Naba block na kasi ang airflow. Kahit 3-4 times a month naglilinis ng filter, may alikabok pa rin na nakakalusot at kapag naipon doon na nagsisimula magyelo..usually 4-6mos.
    Nov 2017
    #1676
    Un pala ung purpose ng isa pang sensor na nakabit deretso sa copper tube ng evaporator ng non-inverter panasonic namin - pang monitor ng frost buildup.
    #1677
    Quote Originally Posted by Mask Rider Blac View Post
    Want longer cleaning interval? To prevent all the dirt & moisture gelling up, run the AC on fan for a while before turning off. My practice is around 30mins to dry everything.
    Mar 2004
    #1678
    hmmm...
    Carrier is rebadged Midea ...
    Jan 2009
    #1679
    That's right. I run an automated routine to do this when we turn off each A/C.
    Drying up the evaporator coils after use impedes the growth of mildew, algae and other bio mass that takes the form of a slimy gel-like substance.
    Jan 2009
    #1680
    AFAIK, Toshiba invented the inverter tech for HVACs in the 80s.
    There was the Carrier-Toshiba partnership back in the late 90's to use some of those tech, but when Midea acquired some 80% stake of Toshiba in 2016, Carrier is now dealing with Midea. So if it gives anyone some comfort, both Carrier and Midea (including a smattering of other brands) utilizes some, if not most of Toshiba's inverter tech.
Split Type Aircon: Which is best?
